Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 02-11-16, 08:45 AM
mayhem's Avatar
mayhem mayhem is offline
OC3D Elite
Yeh it what i have lying around, the air though put is relay good, once i fit the dropper into it this will also be air cooled as they can hit upwards of 85c so not only will we be air cooling the CPU's & GPUs it will be cooling the dropper too. If your going to get fans though get decent ones.....
__________________
All support is now handled direct at http://support.mayhems.net/
  #12
Old 05-11-16, 02:52 PM
mayhem's Avatar
OC3D Elite
__________________
  #13
Old 06-11-16, 10:10 AM
mayhem's Avatar
OC3D Elite
Simplifying the build.
The previous build is complex to assemble so i have re done the drawing and will try a second attempt were its a lot easier to put together. This is a build incorporating the power controller so that the cables do not snag behind the layers of the build. I have added the Power in for the whole build and also the adapter to power converter as well. Ill laser cut these later once the rest of the parts arrive for the second build.
As you can see, you can adjust the build to suit your needs incorporating any type of LCD or power converter.
__________________
Tags
odriod, water cooling, xu4
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
