Go Back   OC3D Forums > [OC3D] Customer Care Forums > MSI UK Forum
Thread Tools Display Modes
  #1
Old 08-03-16, 11:57 PM
Flux Flux is offline
Member
No Post on new Msi Z97 Gaming 3
Hi All
I've been trying to get this new Msi Z97 Gaming 3 motherboard to work in my daughters pc for days. It will not post, no matter what I try to do, to find the issue & I cannot get into the bios.
You just get a blank black screen on boot up & the monitor states no signal, also there are no beeps on the motherboard speaker, I put on the board either, when the the system powers on with everything connected, with what looks & sounds like a fully working system, with fans going, ssd & hard drive working (indicator flashing on front pc when power on) & so on.
I've tried all the things listed below to try find the issue with the board :-
Checked 8 pin cpu plug seated correctly
Checked 24 pin plug seated correctly
Made sure GPU seated and powered
Tried to get a signal though the graphics card and the on board
Tried VGA, HDMI & Dvi cables
Different monitor
No ram = 3 beeps
2 sticks of ram = no beeps
1 stick of ram = no beeps
Ram in slots 2-4 & 1 & 3 = no beeps
Reseated the cpu & cooler
Checked socket for bent pins
Made sure the fans for the cpu cooler connected
Went round the system checking all cables for hard drives fans and such connected.
Reset CMOS via the jumper
Reset CMOS via the battery removal
System spec
I5-4690k
8gb Corsaire Vengence LLP 1600mhz
Msi Z97 Gaming 3
Coolermaster 212+ cooler
Be quite power zone 850w power supply
Gigabyte R9 280x 4gb Windforce
60gb ssd
2tb hard drive
Windows 10
A bit of background leading up to the problem
This was a working system before the last motherboard Gigabyte z97 d3h stopped been able to get into the bios (corrupted bios, seems common board problem), when the Corsair H60 I was using in the system pump failed & overheated the cpu to 90°c +, so I fitted the Coolermaster 212+ & the system worked, but bios issue still remained.
So I got a this new Msi motherboard, off Amazon. Had this bios problem with the Gigabyte board before so got a replacement, but gone with the Msi board this time.
Any advise people can give would be much appreciated.
Thanks
__________________
NEW PC: i7 5820K | Gigabyte GA-X99 Ultra Gaming RGB | Corsair DDR4 Vengeance LED, PC4-24000 (3000) | Nzxt Kraken x62 | Evga gtx 1070 sc 8gb | Corsair AX850 | CM Storm Stryker
OLD PC: i5 3570K | MSI Z77 MPower | Mushkin Ridgeback 2x4GB | Corsair H100i | XFI HD 7990 6GB | Corsair AX850 | CM Storm Stryker
  #2
Old 09-03-16, 03:32 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Just try and move the graphics card down one slot incase its a dead gpu lane and try and see if you get a signal that way also have you checked the gpu in another system and does it work if you get nothing from that then return the board for a replacement tell them it was a DOA
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #3
Old 09-03-16, 06:57 AM
Warchild Warchild is offline
OC3D Elite
I would actually remove the GPU first and try the onboard vga. Just plug a hdmi cable straight into the motherboard.
After that (if it fails) try what Excalabur has suggested. When troubleshooting, its always good to remove absolutely everything that isnt necessary and work from there. I'm talking fans too (including CPU cooling if possible).
edit* I know you say you tried onboard video, but did you try it with the GPU removed?
  #4
Old 09-03-16, 02:58 PM
Member
Thanks for your reply Excalabur50 & Warchild.
I've tried the other gpu slot and its still not working, also I have tried with the gpu removed and with it in, while tying to get the onboard to work, but having no either luck.
I have my sons 1150 socket pc, maybe I could try the cpu on his pc and see if it still works and not been fried.
__________________
  #5
Old 09-03-16, 11:38 PM
OC3D Elite
That's a good idea let us know how you get on
__________________
DRAGON'S MIST
  #6
Old 09-03-16, 11:44 PM
Member
So I've tried the i5 in my sons pc and it works fine.
I've also noticed that on the Msi board the audio boost area is not lighting up correctly, only half of it is.
Working
Mine, the light shows going into the first capacitor at the top of the audio boost chip, then nothing
__________________
  #7
Old 10-03-16, 12:20 AM
OC3D Elite
I suspect it's a dead board and it's time to RMA it
__________________
DRAGON'S MIST
  #8
Old 10-03-16, 07:07 AM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Yeah, sounds broken mate.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #9
Old 10-03-16, 09:08 AM
OC3D Elite
Look at the circuit lanes leading to the audio chip. I suspect you damaged one accidentally when installing the GPU, its very easy to gently tap the mobo with the GPU bracket while installing it and just chipping one of the circuit lanes.
  #10
Old 11-03-16, 05:06 PM
Member
I've checked those circuit lanes around the audio chip and I've not seen anything. Think I'm going to have to RMA it.
__________________
Tags
bios, blank screen, gigabyte z97 d3h, msi z97 gaming 3, no post
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
