Thread Tools Display Modes
  #21
Old 27-09-15, 03:27 PM
JR23 JR23 is offline
OC3D Elite
Originally Posted by jbonnett View Post
Getting better / more RAM soon, and three Titan X's...
Just get two, 3 or 4 ruin the whole experience unless your going to break out the watercooling.
Is your socket ok now?
JR
  #22
Old 27-09-15, 03:57 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
I have to say it was a ballsy move repairing the pins yourself, but kudos for succeeding. Rigs looking great so far and I agree with JR on the Titan Xs, just go dual SLI. Anything else is just a waste of money unless your going to submerge them and rape the volts and clocks.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #23
Old 27-09-15, 06:08 PM
jbonnett jbonnett is offline
Newbie
JR
Haha yeah I am going to make a custom loop, the socket works perfect no problems at all
  #24
Old 27-09-15, 06:11 PM
Newbie
Also getting a red CableMod kit, I don't know if you noticed I overclocked the CPU to 4.2Ghz and the temps are still at an all time low of 37c idle and 48 under load.
  #25
Old 27-09-15, 10:39 PM
Kilbane's Avatar
Kilbane Kilbane is offline
Hagrid Look-A-Like
I don't think you will fit 3 Titans in the S340 case, no clearance below the 3rd PCIe slot for it. Your gonna need a bigger boat .... I mean case
  #26
Old 28-09-15, 08:11 AM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Oooh build log for the custom loop pls
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #27
Old 28-09-15, 10:59 AM
Newbie
I think you're confusing the 3rd slot with the 4th.
Take a look at this:
Posts merged - Please use the multi-quote option
Sure thing, won't be until March though
  #28
Old 28-09-15, 01:39 PM
Kilbane's Avatar
Hagrid Look-A-Like
My bad, forgot there was 4 slots on the board. I will blame it on tiredness. I will however go with the 3 cards are a waste. Scaling over 3 cards just doesn't work very well, to the point that several games don't even run with a 3rd or 4th card installed. This I'm sure will change over time with the newer API's, personally I would run 980Ti's over Titans.
Other than that, build is looking good, look forward to the next instalment.
  #29
Old 28-09-15, 01:55 PM
Newbie
Yes 3 cards do not usually scale well, although that is usually due to a CPU bottleneck. API wise I have no idea I guess I'll see, I'm going for Titans for the RAM I'm going to be doing video editing... Maybe some GPU computing tasks. I want overkill. Check out Skunkworks, Jay runs 3 Titans too
Tags
advice, overkill, upgrade
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
