Thread Tools Display Modes
  #11
Old 14-08-15, 12:16 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Nice work there mate
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #12
Old 14-08-15, 01:38 PM
Pogal_31's Avatar
Pogal_31 Pogal_31 is offline
Advanced Member
Send a message via Skype™ to Pogal_31
Looks more and more impressive, great mod on the 980 Ti !
__________________
  #13
Old 14-08-15, 04:32 PM
Permafrost's Avatar
Permafrost Permafrost is offline
Compo Whore
looks awesome dude! subbed
__________________
  #14
Old 14-08-15, 04:37 PM
RickPlaysWarr's Avatar
RickPlaysWarr RickPlaysWarr is offline
OC3D Crew
Hi
Very awesome solution for your GPU blocks. Have you thought of making a acrylic window to fit in the space where the one on the original heatsink used to be? That way you maintain the original blower properties and all the memory/vrm heat goes out the back of the card. Just drill holes through the replacement window for the pipes
--Rick--
__________________
  #15
Old 14-08-15, 04:59 PM
Mysterae's Avatar
Mysterae Mysterae is offline
OC3D Crew
Thanks for the comments guys, very encouraging .
Originally Posted by RickPlaysWarr View Post
Hi
--Rick--
Indeed I have, great minds huh?! I even have some "glass effect" green acrylic lying around from a previous build although that's 10mm thick! The issue would be getting it exactly like the original profile, quite a bit of work involved. It's something I'm still considering, I'll see how much time I have left.
  #16
Old 14-08-15, 06:00 PM
shambles1980's Avatar
shambles1980 shambles1980 is offline
OC3D Elite
i do enjoy build logs.
And i give this one my thumbs up
I do have a question though. (something i have never comprehended)
Why go parallel?
Is it for the aesthetics?
__________________
i7 2600, intel dz77sl-50k, 16gb 1600 DDR3, 900d case, gtx 780 @ 1306/1727 "xspc block", 1x 240 1x360 1x480 rads 2 bay res, http://www.3dmark.com/3dm/14829772
  #17
Old 14-08-15, 10:01 PM
Mysterae's Avatar
OC3D Crew
Why go parallel?
Thanks for the thumbs up .
Why go parallel? A number of reasons:
1. The GPUs are normally in parallel in my previous builds anyway and that is for aesthetics as well as ease of install, so I thought I'd go parallel with the rest as well, creating a theme.
2. On the aesthetics side, if I were to go series with all blocks I would need a very long return pipe and that would just look odd. So instead this build will have two parallel pipes feeding and returning as you will soon see .
3. I've done parallel before, years ago in a build called 'Parallel Hex'. I learned a lot from that build and proved parallel is possible. However I borked that build by not using a big enough radiator; lesson learned! The thingy in my avatar is a relic from that build.
4. I wanted this build to look a bit different to my previous build 'Black In Control' despite using a lot of the same hardware. The parallel ethos will be it's redeeming feature. As well as two stonking green glowing 980Ti's .
  #18
Old 15-08-15, 03:30 PM
Innocent159's Avatar
Innocent159 Innocent159 is offline
OC3D Elite
That looks amazing
__________________
I don't want a sig anymore
  #19
Old 16-08-15, 11:27 PM
Mysterae's Avatar
OC3D Crew
Update
Originally Posted by Innocent159 View Post
That looks amazing
Cheers mate!
A little update for the tonight; fitted the Koolance PLT-UN40F cold plate and LEDs to the other 980Ti.
Temporarily installed in them in the case to check out the lighting, spacing and tube routing.
I knew I was going to have to remove some of the case to allow different options of tube routing and to be able to see the left hand graphics card.
There's only a few mm between the left graphics card and the fittings of the right one.
Still looking at other options, I'll see how the 45 degree fittings look when installed or if a manual bend of the pipework will make it.
Thanks for reading .
  #20
Old 16-08-15, 11:38 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Loving the mod on the GPU's, Awesome !
__________________
=Origin-Steam-Uplay - Dicehunter=
Tags
aquaero, copper pipes, modding, parallel, water cooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
