Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 22-05-15, 09:34 AM
Thelosouvlakia's Avatar
Thelosouvlakia Thelosouvlakia is offline
Classy-Fried-Chicken
I would love to see that! Whatever the outcome!!
__________________
Theory is when you have the "know how" but nothing works.
Practice is when everything works but no one knows why.
In our lab, theory and practice are combined: Nothing works and no one knows why
  #12
Old 22-05-15, 10:05 AM
YouWhat's Avatar
YouWhat YouWhat is offline
OC3D Crew
You going to go totally ghetto and use a washing machine pump?
Seriously though, that is total overkill!!
__________________
Intel i7 4790K | Asus ROG Maximus VII Hero | 2 x Asus ROG Striker Platinum 4GB GTX 760 in SLI
16GB Corsair Vengeance Pro @ 2400 | Corsair RM 850 | Corsair H100i | Corsair Obsidian 750D
  #13
Old 22-05-15, 10:38 AM
Remmy's Avatar
Remmy Remmy is offline
OC3D Elite
Originally Posted by GuppyFishNoob View Post
pushes about 1000LPM i think
1000LPM pump? O.o I think D5s go up to about 1200L per hour
__________________
  #14
Old 22-05-15, 12:30 PM
shambles1980's Avatar
shambles1980 shambles1980 is offline
OC3D Elite
not sure what pressure you're looking at with a washing machine pump.. id be worried about my tubing and fittings..
I would 100% make a test of tubing blocks pump and rand not connected to anything. outside
__________________
i7 2600, intel dz77sl-50k, 16gb 1600 DDR3, 900d case, gtx 780 @ 1306/1727 "xspc block", 1x 240 1x360 1x480 rads 2 bay res, http://www.3dmark.com/3dm/14829772
  #15
Old 22-05-15, 01:03 PM
GuppyFishNoob GuppyFishNoob is offline
Newbie
sweet now im really looking forward to finishing this project. i shall upload pics of the completed project when its all done and hopefully the temps i get if this works OK. im hoping that by taking the heat out of my case from the CPU as the AIO i have sucks air from the outside to the inside of the case, that i can run the exhausts at low RPM and modify my GPU fan curve so i dont have to mess with the fan speeds at all whether gaming or idle.
Posts merged - Please do not double post
yeah ive already leak tested it for 24 hours + when i was applying the araldite so it shouldnt leak. ill do another 24 hour test when i hook the loop up and before i first power it on. na its not a washing machine pump, just an aquarium pump for a pond or tank etc. but i made sure it had a decent amount of power before i bought it. roughly 1000LPH and like 3.2m of head or something like that.
  #16
Old 23-05-15, 06:46 AM
YouWhat's Avatar
OC3D Crew
..... the AIO i have sucks air from the outside to the inside of the case
Why can't you just flip the fans around on the AIO?
__________________
  #17
Old 26-05-15, 04:32 AM
Newbie
hey guys ive had issues with the radiator leaking so i need to redo one of the plugs before i can paint it. so instead of waiting ages for pics of the finished product i think i might just make a build log album or something. oh FYI i checked the pump specs and it pumps 2500LPH with 2.3m of head
  #18
Old 10-06-15, 10:34 PM
Genesius Genesius is offline
Advanced Member
Hi mate, I too have built a pretty unconventional cooling loop, ill post links at the bottom.
with the rad you wont need any fans. I have 8 ltrs in my loop, I have a rad but the fans never kick in.
Your main issue is that pump. the block you have wont handle that kind of flow, it will cause back pressure and you will have tubes popping off like hose pipes, (ask me how I know), so you need to test that block and see how much its max LPM is then get a pump that can do that. anything over that will cause excess pressure and will damage the pump.
Oh also, you cant bore them out to improve flow rate. well you can, and flow rate improves, cooling will degrade though so theres no point, (been there done that).
So my advice is, change the connectors on the rad to step down hose tails from a pond shop, jubilee clip them in. Then get a smaller pump, or you could create a bypass loop with a ball valve and have the excess LPM run around that. and back, the ball valve will let you fine tune it.
hope this helps
http://forum.overclock3d.net/showthread.php?t=51233
http://forum.overclock3d.net/showthr...t=51113&page=3
http://forum.overclock3d.net/showthread.php?t=51855
__________________
Gigabyte Z77X-UD5H
3570k @ 5ghz
16gb Corsair Vengence 1600mhz
Eheim Aquarium pump custom loop (DONE!)
Corsair CX750M
EVGA GTX 1070 FTW
  #19
Old 13-06-15, 02:54 PM
Newbie
ive redone the plugs on the radiator and it is now leak free the barb fittings for the watercooling tubing havent leaked since i first epoxied them in but the plugs on the other holes have, theyre all fixed now. and as for the block when i first got the parts i leak tested it all for a 24 hour period and there were no leaks from the block at all. the flow was really good, the hoses didnt come off or leak at all but i did have hose clamps attached as well. now its just to finish the paint, buy more UV blue dye then to attach it all to the PC.
Tags
diy, gaming, passive cooling, water cooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
