Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #1
Old 07-01-15, 03:58 AM
sweet sweet is offline
Newbie
what kind of do i need power supply for a GeForce GTX 750 Ti 2GB WTF
my SYSTEM specs...
Operating System
Windows 7 Ultimate 64-bit
CPU AMD Phenom II X4 960T
RAM 4.00GB Single-Channel DDR3 @ 668MHz
Motherboard MICRO-STAR INTERNATIONAL CO.,LTD 880G-E45
Storage 186GB MAXTOR.
i have a few power supply's i think might work???..
EVGA 500W 80PLUS CERTIFIED...
CORSAIR CX 500W
ANTEC VP-450W
would any of theses work with that card GeForce GTX 750 Ti 2GB WTF
  #2
Old 07-01-15, 06:51 AM
YouWhat's Avatar
YouWhat YouWhat is offline
OC3D Crew
All the PSU's you listed above would work, you will probably be looking at around 250 to 350W max pulling from the wall with that setup, so those listed above would work very easily, but I wouldn't go lower than a 450W as that way it gives you some wiggle room for upgrades eg mobo + RAM + CPU when you can afford to as the gfx card and PSU would easily transfer across and as long as you don't go overboard on setup, it all should play happily together.
__________________
Intel i7 4790K | Asus ROG Maximus VII Hero | 2 x Asus ROG Striker Platinum 4GB GTX 760 in SLI
16GB Corsair Vengeance Pro @ 2400 | Corsair RM 850 | Corsair H100i | Corsair Obsidian 750D
  #3
Old 07-01-15, 07:54 AM
AverageNinja's Avatar
AverageNinja AverageNinja is offline
Average Penis Too
^^ I second this. 450w would be ample.
Corsair PSU's are one of the best around and the brand of choice for many people on these forums. Not sure about Antec. In another thread on the forums I read that EVGA PSU's are supposed to be Re-branded Superflower PSU's, which are very good.
__________________
JavaBean: Ryzen 5 1600 / Corsair ML240L RGB / ASUS Crosshair 6 Hero / 16GB Corsair LPX / ASUS RX 580 Strix / Corsair RM750X / Fractal Design Meshify C
OC3D Overclockers Club Member:
Nr. #00 (Club Owner)
  #4
Old 07-01-15, 06:31 PM
RandomBadger's Avatar
RandomBadger RandomBadger is offline
Advanced Member
Id play it safe and get something like Corsair AX1500i
  #5
Old 07-01-15, 06:38 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
There's a place for fun on this forum, it's called 'Off-topic'. It's not here.
@OP As said 450Watt will be plenty and pretty much all these units will be fine. Personally, I'd go for the Corsair unit but then spend an extra 3 quid on the CX500M, which is semi-modular and saves you from cable clutter
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #6
Old 07-01-15, 06:52 PM
Advanced Member
Doh!......
  #7
Old 07-01-15, 06:55 PM
tinytomlogan's Avatar
The Guvnor
RM450 would be epic for this tbh if you have the budget for it
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #8
Old 07-01-15, 07:02 PM
Advanced Member
On a SERIOUS not something like this might do the trick
http://www.overclockers.co.uk/showpr...-167-CS&tool=3
  #9
Old 07-01-15, 07:05 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
I can vouch for the Corsair CS series PSUs especially the CS650M, Gold rated and barely even breaks a sweat when gaming hard with the 750ti and nice price points. Over kill for me as I only draw around 320w max from the wall.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
Tags
graphics cards, power supply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
