Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
Thread Tools Display Modes
  #101
Old 12-02-15, 09:25 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
An alternative might be the Sennheiser IE80 or IE60 imo they sound better than the 215 but i have no clue how the 315 sound
  #102
Old 12-02-15, 09:28 PM
SieB's Avatar
SieB SieB is offline
OC3D Elite
Cheers, i'll look into those I love the SE215s but I have had them for 2 years now and fancy something different.
__________________
NZXT Switch 810 - i7 6700K - MSI Z170A Krait - 32GB Corsair Platinum SE - MSI 1070 - Crucial MX100 256GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair RM1000i SE - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
  #103
Old 12-02-15, 09:33 PM
iBeInspire iBeInspire is offline
OC3D Elite
What in particular do you like about the se215?
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
  #104
Old 12-02-15, 09:37 PM
SieB's Avatar
OC3D Elite
Just the overall sound, they are the first decent pair of IEMs I have owned though. I always used to buy cheap ones before which would break after a few months and ended up costing me more than just buying a decent pair.
I can't compare them to anything else really, but I want to step up from them and seen as the 215s are good the next logical step would be the 315s. But i'm just wondering if going from the 215s to the 315s is a worthy upgrade, or if there is a better alternative.
__________________
  #105
Old 12-02-15, 09:58 PM
OC3D Elite
If you're ready to pull the plug and get something a little more audiophile-centric, with a harsher but far more revealing sound I would recommend Etymotic ER-4P. Should be improvements across the board ~ highs, mids, especially lows should be a lot cleaner.
__________________
  #106
Old 12-02-15, 10:10 PM
SieB's Avatar
OC3D Elite
Cool, i'll check them out. One thing the 215s lack on is mids, the bass dulls them out and makes them a bit flat. So it would be nice to have something with a bit more of a cleaner sound, especially in the mids.
__________________
  #107
Old 12-02-15, 10:21 PM
JR23 JR23 is offline
OC3D Elite
I've got some SE310's that I found really cheap on ebay. I was originally going to get 210's but read they were pretty weak in the lows but couldn't find enough money for new 310's which at the time were serious £. Before that I only had mediocre Sennheisers and they really shocked me, they are still solid today although I only use them occasionally on the train mostly.
I must say though, controversially they sounded by far the best on my One X+ with beats BS enabled, unless they gimped the standard EQ to make it sound awful they come across somewhere inbetween with my G2.
JR
  #108
Old 13-02-15, 12:49 AM
AMD Enthusiast
As far as i know the best phones that give the best sound are HTC One M7 and newer models. Simply because they put the most power to the jack so it can drive stuff higher with less distortion. Think the Lg G3 was the next best none htc phone for audio.. can't remember exactly.
If you get a real high end set you may need a portable amp.
  #109
Old 15-02-15, 08:01 PM
SieB's Avatar
OC3D Elite
Anyone in the UK had ear impressions done for custom headphones?
Where did you go and how much did it cost?
EDIT: Currently looking into these guys, they are the cheapest I have found so far.
http://www.acousticare.co.uk/earphon...ves/4579136523
Also these
http://www.minerva-hearingprotection...e-sleeves.html
Just found out that Boots with a David Ormerod department apparently do custom sleeves for £88 including the ear impressions. Looking into that also.
Woot! my Etymotic ER-4PT have arrived
Thanks for the recommendation iBeInspire, they are a good upgrade from my SE215s.
__________________
  #110
Old 18-05-15, 05:35 PM
Thelosouvlakia's Avatar
Thelosouvlakia Thelosouvlakia is offline
Classy-Fried-Chicken
Requesting permission to join the club
__________________
Theory is when you have the "know how" but nothing works.
Practice is when everything works but no one knows why.
In our lab, theory and practice are combined: Nothing works and no one knows why
Tags
amps, audio, dacs, headphones
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
