Go Back   OC3D Forums > [OC3D] Customer Care Forums > MSI UK Forum
Thread Tools Display Modes
  #1
Old 31-10-14, 02:32 PM
MSINotebookUK MSINotebookUK is offline
Newbie
GS60 – Thermal Performance
During our previous overclocking tests of the GS60 we discovered that it comes with a nice performance to weight ratio, but we were also slightly surprised by the fact that the computer had no trouble supporting quite serious overclocking of the graphics card either.
Logic dictates that the slimmer a notebook is, the harder it is to fit large cooling solutions – that’s why we can cool the 980M and any mobile CPU in the GT72 with ease, while keeping it quiet. The GS60 though, is under 20mm thick including screen, meaning that space for cooling is critical.
The obvious way is to throw in a couple of fans with massive RPMs, but that would be extremely noisy. Another way would be to make the system thicker to allow more space for the cooling fins, allowing for a larger convection area helping you exhaust the heat, which of course makes the system bigger, heavier and less mobile. Instead, we’ve worked with the space available and managed to create a system that stays surprisingly cool even under full load.
Yes, we’ll have to admit – it’s not whisper quiet, but nowhere near as bad as you might imagine by looking at how slim the GS60 is. All things considered, we believe it is at a sweet spot where it stays quiet for everyday use, while making itself known during gaming, which is when you have a headset on anyway, right?
We’re always partial to a benchmark, so we set about finding how hard we can push the GS60’s thermal solution… In doing so, we got nowhere near the limits of the GTX 970M, despite a 20 minute loop of game test 4 in 3DMark 11, meaning constant 100% load on the GPU. In 22°C room temperature, we maxed out at 85°C on the GPU, despite overclocking it to the max, thus creating extra ”excess” heat.
Of course the system was audible, but even when set in an office landscape with people working all around during the benchmarks, nobody as much as lifted an eyebrow
In case you’re worried about the cooling of the GS60, you shouldn’t be, it leaves plenty of headroom for the processors.
  #2
Old 31-10-14, 02:35 PM
KING_OF_SAND KING_OF_SAND is offline
OC3D Elite
Wow, I just just asked about the GS60 with the 970m and the 3k display literally about 10 minutes ago on this forum. I'm really considering it for my next laptop under $2000.
  #3
Old 31-10-14, 02:53 PM
Newbie
Nice if you got any questions let me know!
  #4
Old 31-10-14, 02:56 PM
OC3D Elite
How does it handle BF4 at max settings including 3k. I know this sounds like a silly question but it will help me gauge on the performance of it.
Second is the 970 and or Intel CPU throttled performance wise due to its size? Most thin notebooks cough* cough* Razer Blade are throttled performance wise to maintain lower thermals.
  #5
Old 31-10-14, 03:20 PM
Newbie
I haven't seen any benchmarks on BF4 yet, I searched quickly on google though and found this on a forum ( I don't want to give external links )
'Ive just played BF4 (3k,ultra on everything)for over an hour on high performance+sport mode msi settings.
Temps : gpu 81, cpu 83.
It was beautiful, smooth and without any problems (cant tell you fps though, i was to lazy to look for fps command
Fans went to some rly high rpms but it wasnt annoying, just noticable.'
Usually our GS range keep performance high even when heat it high, looking at some reviews online should give you more of an idea! (again don't want to give external links)
hope this helps!
  #6
Old 31-10-14, 03:27 PM
OC3D Elite
Well if you do come up with results please post them
Tags
gaming, gs60, laptop, msi, notebook
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
