Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
Thread Tools Display Modes
  #1
Old 25-10-14, 04:41 AM
PC-Noobist PC-Noobist is offline
Newbie
Amp/Headphones Impedance
Hi, the amplifier i have for my speaker setup only supports up to 50ohm headphones (according to the manual and website) but im buying 60 ohm headphones and a proper headphone AMP/DAC later on, what are the downsides in doing this without the AMP/DAC, cant afford the AMP/DAC right now, any help in telling me what might happen will be VERY much appreciated, THANKYOU!
  #2
Old 25-10-14, 06:09 AM
Eniac The First Eniac The First is offline
Banned
Use the 1/8 rule of impedance for the best sound quality.
Most headphones work best when the output impedance is less than 1/8th the headphone impedance. So, for example, with 32 ohm Grados the output impedance can be, at most, 32/8 = 4 ohms. The Etymotic HF5s are 16 ohms so the max output impedance is 16/8 = 2 ohms. If you want to be assured a source will work well with just about any headphone, simply make sure the output impedance is under 2 ohms.
Tags
amplifier, headphones, impedance
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
