Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #11
Old 23-10-14, 09:16 PM
iBeInspire iBeInspire is offline
OC3D Elite
For the budget your best bet will be to spend as much as possible on a GPU, then sort out your CPU upgrade later on. The GPU upgrade will give you the bulk of he performance increase which is what you want in the first place, and then later on the CPU will be the icing on the cake.
If you have an aftermarket CPU cooler I would also advise overclocking the CPU as far as it can go for the time being
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
  #12
Old 23-10-14, 09:39 PM
Sorokinn Sorokinn is offline
Newbie
Originally Posted by Pc-convert View Post
I just put a posted a new thread as i found a egva gtx 780ti dual classified at Dabs for only £350, it was returned open unused so for £350 for a beast of a card is a no brainer.
Oh, awesome! Looking now, can't seem to find it though xD
  #13
Old 23-10-14, 11:10 PM
RadeonHDx RadeonHDx is offline
OC3D Elite
I've seen the 780ti for £299 on overclockers I think. I'd also recommend the 970 or 780 if you can find one for good money. As far as the CPU goes, you'll see the biggest improvements with a better CPU in the older games such as Skyrim an other games that use DX9, were as in the DX11 games you'll see the bigger improvements with a better GPU.
__________________
Intel Xeon E5649 x2 | Custom Water Loop
Saphire R9 290 Tri-X Edition | InWin Dragon Rider White
24GB Samsung RAM | SuperMicro X8DTi R2.0
Samsung Evo 250GB | 1TB Hitachi HDD
  #14
Old 24-10-14, 03:30 AM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
I bought the Asus 970 Strix its such a lovely card but possibly not the best 970 overclocker as the single 8 pin restricts the power a bit if you want one to overclock go with the gigabyte 970 or Msi Gaming but if you think the 780 or 780 ti would suit your needs then go for that personally I wanted a card thats new out
As you are looking to play upcoming Games I would go for the 970 as it has 4gb of ram
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #15
Old 24-10-14, 03:33 AM
Eclipse Computing PC Eclipse Computing PC is offline
Banned
Double up your memory while you are at it, it will make a huge difference for you.
  #16
Old 24-10-14, 08:01 AM
MadShadow MadShadow is offline
OC3D Elite
He already has 8GB! You really dont need more for games, especially at 1080p these days.
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #17
Old 24-10-14, 10:56 AM
tinytomlogan's Avatar
The Guvnor
Handing out advise like that you shouldnt really be allowed to build systems for someone because you blatantly dont know whats actually required, how components work or get utilised.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #18
Old 28-10-14, 05:40 AM
Crocodile Crocodile is offline
Newbie
Originally Posted by JR23 View Post
There have been some very cheap 780's around, the DCUii was £230 briefly at OCUK but they are all gone now. Scan have the DCUii 780Ti for £339, ebuyer have a Twin Frozr 780 for £234. It just depends what deals you find and what coolers you like I guess, there are still some 7-series bargains to be had but it's not like the 9-series are outrageously priced.
For 1080p a 970/780 are a good choice but I guess some 780Ti overkill wouldn't hurt. 980 prices just don't make sense yet IMO.
JR
I bought two Asus gtx 780 DirectCU II for $330 each.
  #19
Old 28-10-14, 04:01 PM
RandomBadger's Avatar
RandomBadger RandomBadger is offline
Advanced Member
Just an update, the Egva 780ti dual classified is now only £328, almost tempted to cancel my Egva 980 order and get the 780ti until nvidia release the 980ti or equivalent. What are the thoughts of other forum members.
  #20
Old 28-10-14, 06:16 PM
AMD Enthusiast
If its much cheaper then it would be worth it. Otherwise not really. You're only playing at 1080p right now and tbh either card is way overkill so it doesn't really matter. The performance is slightly better on a 980 and you also get more Vram. Up to you to decide if that's worth it or not. Also should keep in mind a 980 will hold on to its resale value longer, since as you can see a 780ti didn't for long.
Tags
amd, gpu upgrade, graphics card upgrade, nvidia
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
