Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 29-09-14, 12:58 PM
Sorokinn Sorokinn is offline
Newbie
New PSU - Back and side fan stopped working
Okay, so I wasn't exactly sure where to post this so thought I better start here since the PSU I bought is a Corsair CX600M. Basically, when installing this, everything went fine (as far as I know) but when testing the system, there's no power going to the back and side fans. The case is a Cooler Master HAF932 Advanced. I'm pretty new to building/rebuilding systems, having only done a full system once before, so I'm not really sure what things to look out for. Any response is appreciated and just ask if you bed any more information.
Cheers!
  #2
Old 29-09-14, 01:03 PM
tinytomlogan's Avatar
The Guvnor
Nothing to do with the PSU matey - check all your connections etc.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 29-09-14, 01:12 PM
Newbie
Connections are fine, I'll take another look in a bit but not sure what else to check haha; thanks for the reply though, Tom!
  #4
Old 29-09-14, 08:17 PM
BigBlue1 BigBlue1 is offline
Banned
To check, connect the fans to a known working 12v source. Use your multimeter to make sure the power is there.
  #5
Old 29-09-14, 11:05 PM
paulstung's Avatar
paulstung paulstung is offline
OC3D Elite
Try them in a motherboard header would be the easiest way of testing them mate. If they are connected via Molex just check that all the pins are fully pushed in, I had a few problems with the 7v reducer cables that came with my fans last week, it was almost like they didn't want to go in, but when they did, there was always one that wouldn't be, so from behind with a small pair of pliers I just pushed it in from behind.
Tags
corsair, first post, help needed, new member, power supply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
