Go Back   OC3D Forums > [OC3D] Graphics & Displays > Screens and Displays
Thread Tools Display Modes
  #1
Old 02-08-14, 10:02 AM
ryanbutik ryanbutik is offline
Newbie
What's the best monitor for the money below 200$
I would like to ask what are the monitors is best for the 200$ and below bracket...
Please specify the brand and model number if you do so kindly
I ask this because I would like to build PC, but I adjust my components that I pick because I don't have a monitor, so I went here asking
Thanks for the response that will be made
  #2
Old 02-08-14, 10:05 AM
Cru's Avatar
Cru Cru is offline
OC3D Elite
if possible i'd go for this one, slightly above 200 with the current discount
http://www.newegg.com/Product/Produc...-292-_-Product
  #3
Old 02-08-14, 11:15 AM
GadgetGarrett GadgetGarrett is offline
Member
There's some bargain IPS monitors by QNIX and Yamakasi that I'm currently thinking about buying. They have around 4ms refresh but, being IPS, the colours should pop.
I understand that they use the same panels as Samsung, etc. Might be worth seeing if you can get a bargain.
__________________
Blue and White Stryker
CM Storm Stryker | Zotac GTX780 AMP! | 4x4GB Vengeance RAM | Core [email protected] | H80i | Corsair K60 & M65
  #4
Highlander89's Avatar
Highlander89 Highlander89 is offline
Advanced Member
I got one of these
Paid 170€ for it.
__________________
I7 4790K -- Asus Z97-AR -- GTX 770 4GB -- 16GB DDR3
840 EVO -- WD Green 3TB -- CS 750M -- NZXT 810 -- BenQ GL2450 -- Asus ROG PG279Q
XSPC Raystorm -- Heatkiller GPU X3 -- Alphacool D5 -- Noiseblocker Blacksilent -- 420 & 360 Nexxos UT60
--P180 Resurrection--
  #5
Old 02-08-14, 11:34 AM
Newbie
thanks for your responses...
i will look into the BenQ, but the retailer only have the GL2460 model it seems like it is an updated model....
(update): it seems that it is pricier here than what I have expected...then I stumbled to the monitor of ASUS VX239H...it cheaper for about 20$...is this monitor of ASUS good...?
  #6
Old 02-08-14, 04:41 PM
Advanced Member
as always, search is king.
Review 2
Review 3
__________________
  #7
Old 03-08-14, 02:49 AM
Newbie
thanks sir Highlander89...
Tags
monitor
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
