Go Back   OC3D Forums > [OC3D] Cooling Forum > Cooling - Other
Thread Tools Display Modes
  #1
Old 28-06-14, 02:21 AM
tandt tandt is offline
Newbie
Exclamation Power supply - Thermoelectric Cooler Peltier Plate Module
Thermoelectric Cooler Peltier Plate Module Specifications:
Model: TEC1-12706
Voltage: 12 V
Umax (V): 15 V
Imax (A): 4.3-4.6A
QMax (W): 72 W
I connect the TEC to a power supply as shown in the image here:
Could somebody please tell me if it is OK?
Will it destroy the TEC because (to my tiny knowledge in electricity) it looks like the TEC operates from 4.3-4.6A but the amps of the yellow line of the supply power is 10A?
  #2
Old 08-07-14, 04:21 PM
thoolooexpress thoolooexpress is offline
Newbie
The yellow is 12v, the cooler requires 12v, and it is below the capacity of the power supply, so that should mean you're good to go. Just be careful you aren't exceeding the maximum capacity of your 12v rail with your other parts, a cheap PSU like the one you have will take your other parts with it when it fails.
  #3
Old 11-07-14, 06:07 AM
Newbie
Thank you very much.
Tags
power supply, tec, thermoelectric, thermoelectric cooler
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
