Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #11
Old 11-03-15, 05:41 PM
tinytomlogan's Avatar
The Guvnor
Originally Posted by Xrqute View Post
considering air cooling on 4790k
You considered wrong hahaha :-)
4790K really isnt hot but the D15 is soooo fat. The CM V8 GTX isnt really that great IMHO - any aircooler will be louder than a AIO watercooler though. Considering your case supports it I really think you should reconsider the aircooling option unless youre not fussed about noise
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
Tags
cooling, devils canyon, noctua, overclocking
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
