Go Back   OC3D Forums > [OC3D] Cooling Forum > Cooling - Other
Thread Tools Display Modes
  #1
Old 25-04-14, 10:59 PM
jwilliamson1121 jwilliamson1121 is offline
Newbie
Swiftech h320 space issue, gpu blocked by fans
Hi, I recently found a bargain and got a Swiftech h320 for £89.99. I knew upon buying that it would fit in the front of my Corsair air 540. However, the after mounting it, I noticed that the fans would obstruct my 12 inch gpu, 290 tri-x and I could only fit both items, by removing the middle fan on the rad. Will this be ok? At the moment I'm running the rad with 2 fans, one on the top and one on the bottom and the gpu is expelling air onto the radiator?
Would I be better in returning the item and getting something smaller? Or stick with what I've got (which I would prefer considering how amazing this cooler is)
  #2
Old 26-07-14, 08:27 PM
kenny01924 kenny01924 is offline
Member
Send a message via Yahoo to kenny01924
ive got one of these a swiftech h320 but mines fitted in a corsair 900d ive put mine in push pull totalling six fans very good watercooling unit id keep it as the shops in the uk don't seem to stock theses any more you have to go direct to swiftech what a shame it will cool your cpu with two fans .
  #3
Old 26-07-14, 09:55 PM
MadShadow MadShadow is offline
OC3D Elite
Yeah, it should be fine. It wont cool as well of course, but it should be sufficient for some decent overclocks.
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #4
Old 16-08-14, 08:39 AM
jones jones is offline
Newbie
The rad should work fine just depends how ocd you are about having a missing fan?
Tags
cooling, cpu cooler, h320, swiftech, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
