Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 08-04-14, 10:38 PM
samm_ samm_ is offline
Newbie
Smile 7990, 7970 x2 or r9 290x?
Hi, I need some help here, I'm planning to upgrade my PC graphics from my 7970, I'm wandering what the best option would be considering performance for value etc. Also I know that the 7990 and 7970's are getting hard to get hold of now and also there is the r9 295x2 being released this month but seems to have a steep price.
Thanks in advance.
  #2
Old 08-04-14, 11:13 PM
CalVic's Avatar
CalVic CalVic is offline
Advanced Member
Send a message via Skype™ to CalVic
Heya,
Welcome to the forum
It comes down to how much you want to spend, As well as other factors such as what resolution your playing games at etc. However, if you can afford it the 290x is a good card
__________________
| 4790K 4.6Ghz @ 1.15v / Uncore @ 4.6Ghz | Avexir 16GB 2133Mhz CL9 | Asus Maximums VII Formula |
| Gigabyte G1 980 GTX | NZXT S340 | Corsair H110i GTX |
EAT-SLEEP-OVERCLOCK
  #3
Old 08-04-14, 11:26 PM
AMD Enthusiast
290x over the other two options. You would be able to get the best 290x on the market for cheaper than a 7990...
  #4
Old 08-04-14, 11:27 PM
lAnimal's Avatar
lAnimal lAnimal is offline
Member
Since you already have a 7970, scan have got a few 'new' (old) 7970's for fairly cheap, that's what I'd go with
http://www.scan.co.uk/shop/computer-...n-hd7970-pci-e
Or sell your one and go for a 290x
  #5
Old 08-04-14, 11:31 PM
AMD Enthusiast
While Xfiring the 7970's would be the fastest out of the 3 it would still consume more power and heat and noise. A single 290x would be better and it has better Xfire support if OP ever decides to do that.
  #6
Old 09-04-14, 12:23 AM
Newbie
I noticed the 7990 is expensive for what it is, which puts it at the bottom of the list out of the choices. In my PC case I have 7 fans so cooling isnt a problem, as for power I have a seasonic gold 1kw, the noise probably wont be an issue as my pc makes quite a bit of noise on full load anyway; I have loud speakers so I don't really hear to much of it.
If I can get a 7970 cheap then I may go for that option since its the easiest. I've been told a r9 280x will CF with a 7970 and also that 2 different 3rd party branded 7970s will CF if the clocks are the same.
Thanks for the replies.
  #7
Old 09-04-14, 12:29 AM
iBeInspire iBeInspire is offline
OC3D Elite
From a pure performance standpoint, the xfire 7970's are probably the way to go, but if you want to stay sane, go for the 290x... crossfire issues are endless.
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
  #8
Old 09-04-14, 08:16 AM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
A 290P is quite a bit cheaper than a 290X and will give you a nice boost over a HD 7970. If after a while a single 290P is not enough you can add a second later.
__________________
#041
GTX 960 owner and proud of it.
  #9
Old 09-04-14, 09:04 AM
KING_OF_SAND KING_OF_SAND is offline
OC3D Elite
Always go with a single GPU when you can. Less driver problems and more compatibility, less heat, and if you really give a rats ass less power.
  #10
Old 09-04-14, 09:49 AM
SeekaX SeekaX is offline
OC3D Elite
Here's an even better idea. Don't upgrade just yet, the 7970 will still do you fine till the next gen and then you can get a new single GPU.
Tags
7970, 7990, crossfire, enthusiast, r9 290x
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
