Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #11
Old 30-03-14, 07:58 PM
irconfus3d irconfus3d is offline
Newbie
Originally Posted by NeverBackDown View Post
Well which CAD version is it? If it supports other cards besides the FirePro or Quadro then its worth getting 780ti SLI/290x Xfire(depending on OpenCL support). Otherwise if it was me personally i would just build 2 rigs.. one for workstation purposes and a different one for gaming. You have a big enough budget to do so and the gaming rig could be used while the workstation renders and stuff. Beats swapping out the GPU every day.
there are some different programs, i need to check that for sure.
and your solution will be the best. 2 different builds
  #12
Old 30-03-14, 08:23 PM
AMD Enthusiast
Check which programs you will use. As that will really end up deciding which GPU you need to get and ultimately probably only one system vs two.
Tags
780 ti, power supply, rm 750w
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
