Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 26-02-14, 04:55 PM
cuylar cuylar is offline
Newbie
Question PCIe 16x
I'm in the process of of completing a $4,000 build and I need some advice.
I realize this is a motherboard question but it's directly related to the graphics cards.
I plan to be doing 1440p gaming with max settings and AA. I want my frame rates to be at least 120+. I've chosen the 780TI as my platform and I'll be doing SLI.
I think 2 cards at the moment will meet my needs.
My question relates to the PCIe slots.
Some boards like the Asus Rampage 4 Black can use 2 PCIe 3.0 slots at 16x... but other boards will only let you use one slot at 16x.... if you use 2 cards you will be limited to 8x.
How will the 16x in SLI vs the 8x in SLI matter to my frame rate?
Thank you in advance.
  #2
Old 26-02-14, 04:59 PM
tinytomlogan's Avatar
The Guvnor
I think the point here is 1440p - max settings 120FPS wont happen unless its crappy games - see the review below. So Id consider that before worrying about PCIE lanes.
http://www.overclock3d.net/reviews/g...d_sli_review/1
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 26-02-14, 07:44 PM
Newbie
Yikes... I guess I've been focusing on maximum fps in other articles read.
Ok... well thank you.
  #4
Old 26-02-14, 09:29 PM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
To answer your question using two cards on a RIVE BE @PCI-E 3.0 x16 compared to x8 gives very little difference in performance, less than 1%.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #5
Old 26-02-14, 10:49 PM
Newbie
That must be a programming limitation though.... Or is it that the hardware isn't built to handle it?
  #6
Old 27-02-14, 07:52 AM
Kaapstad's Avatar
OC3D Elite
There is more than enough bandwidth on PCI-E 2.0 x16 or PCI-E 3.0 x8 to handle any of todays top end cards.
__________________
#041
Tags
16x, fps, pcie, sli
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
