Go Back   OC3D Forums > [OC3D] Processors & Platforms > Overclocking
Thread Tools Display Modes
  #1
Old 02-02-14, 05:32 AM
Harishanim Harishanim is offline
Member
Exclamation i7 4770k overclocking problem!
I've disabled the speed step, set power options to high performance, i cranked up all the cores to 44 in the BIOS but still i end up with only 800MHz, even on a occt test , i even reset the cmos and tried everything over!
__________________
  #2
Old 02-02-14, 10:02 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
You got the latest Bios for your board ?
Just an idea
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
Battle.Net: Dicehunter#2746
  #3
Old 02-02-14, 12:05 PM
Member
Yup it's upto date!
__________________
  #4
Old 02-02-14, 12:13 PM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
post some screen shots of cpu-z and occt running with hardware monitor as well
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #5
Old 02-02-14, 12:14 PM
tinytomlogan's Avatar
The Guvnor
someone show him our overclocking guide - volts have not even been mentioned.......
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #6
Old 02-02-14, 03:43 PM
MrKambo's Avatar
MrKambo MrKambo is offline
OC3D Elite
Send a message via Skype™ to MrKambo
Have a watch of this, and then go from there
__________________
steam|origin|insta:mrkambo
  #7
Old 02-02-14, 05:40 PM
Member
seen the video a couple times now and i did set the voltage a little higher, but here's the image u needed and i have no idea why my gpu is trying to push so much
__________________
  #8
Old 03-02-14, 09:24 AM
MrKambo's Avatar
OC3D Elite
I would change the testing mode to Linpack, also have you raised the power limit for the CPU?
__________________
  #9
Old 03-02-14, 10:59 AM
Member
the volt was actually low but i changed it higher now! and still this is the result
__________________
  #10
Old 03-02-14, 11:04 AM
Member
tried with linpack too, same result
__________________
Tags
problem, processor
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
