Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 29-01-14, 03:03 PM
dladdin's Avatar
dladdin dladdin is offline
Member
new graphic cards?
hey people.....
right i am looking at new gpus, would like to get a bitter more preformance out....
i have a hd7770 asus 2gb card at the min and would like to either crossfire this card with another....or more to the green side gtx 7??
but dont know what to do....
any help? not got loads of money so dont be like 780ti... done
would have to save a pot up to buy in the new card !!!!!
thanks dgladdin
  #2
Old 29-01-14, 03:06 PM
MadShadow MadShadow is offline
OC3D Elite
What's your budget?
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #3
Old 29-01-14, 03:07 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
How much would you be able to save for? I'd aim for a 660 max considering your CPU is a bit -ahem- on the lower end of the spectrum. crossifred 7770s can do quite well if crossfire is supported by the games you play. you should think about upgrading to an 8320/6300 as well.
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #4
Old 29-01-14, 03:14 PM
OC3D Elite
You can always consider AMD's new APU's. Apparently, they are quite good (I haven't gotten any specs). Plus, there is always a chance to upgrade the GPU later. Migh be a decent idea to do a bit of a refresh to your system. An APU would handle the older CPU problem you have and be a GPU for the time being. Just another option to connsider. :P
__________________
  #5
Old 29-01-14, 03:15 PM
dladdin's Avatar
Member
yeah i will be need a new motherboard. then cpu then new or second gpu !!!
think i could save 250 ish on a gpu
  #6
Old 29-01-14, 03:16 PM
OC3D Elite
One day, you will have to do it anyway. Might as well do it now.
__________________
  #7
Old 29-01-14, 03:18 PM
dladdin's Avatar
Member
i am doing it soon....
  #8
Old 29-01-14, 03:29 PM
barnsley's Avatar
born in a.....
Don't bother about the APUs until they release the Athlon versions without the gpu bits. If you did go for an apu it'd still be an upgrade in the CPU department as they actually have better single core performance than most FX cpus!
__________________
Tags
amd, gtx
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
