Go Back   OC3D Forums > [OC3D] Cooling Forum > Cooling - Other
  #1
Old 29-12-13, 02:11 PM
Ghost-Script Ghost-Script is offline
Newbie
Question Fancontroller
Hi Guys and Girl`s
I am in the work on a 900D Build whit 2 480mm and 1 240mm Rad, so whit all the fans togehter i am up to about 14 fans, i would like to avoid Corsair Link, i own it but i crashes all the time, and i would like to have a clean look so if could avoid a fancontroller, but insted use Fan expert2 to run all my fans.
( 13 SP120mm 1 AF140mm )
i Was wondering if i could use 2 of them.
http://www.performance-pcs.com/catal...ducts_id=38706
Love to hear from you.
Sorry about Spelling
  #2
Old 29-12-13, 02:16 PM
Remmy's Avatar
Remmy Remmy is offline
OC3D Elite
I have little experience with fan controlling software so I couldn't say much about that, but if you did have to go down the actual fan controller route then you'll be able to use a handful of 3 pin splitters without a problem. I have 11 SP/AF fans running off a 6 channel fan controller, and I'm sure it could handle a few more.
__________________
  #3
Old 29-12-13, 02:26 PM
tinytomlogan's Avatar
The Guvnor
1x 3pin to 6 x 3pin - I use two of these in orca with a single fan reducer on one end that is then connected to a 12v molex
http://www.aquatuning.co.uk/product_...----black.html
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #4
Old 29-12-13, 02:34 PM
Remmy's Avatar
OC3D Elite
When I tried running three SP120 QEs through splitters all on one Corsair fan speed reducer to 12V molex, the resistor got really hot, so instead I put a reducer on each fan before going to the splitters and then they didn't get so hot.
Does it not do this with yours? Especially with 6 attached through one of them as well
__________________
  #5
Old 29-12-13, 02:53 PM
The Guvnor
Yeah you can feel the warm patches on the side panel - but they have been fine right through the summer etc and still work fine. They are ceramic after all so designed to get hot.
I did it this way to make it easier to keep tidy.
__________________
  #6
Old 29-12-13, 05:06 PM
mehere's Avatar
mehere mehere is offline
OC3D Crew
you could mod the molex to give you 7v
__________________
build log
  #7
Old 29-12-13, 05:12 PM
Remmy's Avatar
OC3D Elite
Sticking the supplied fan speed reducers from Corsair on the fans before connecting it to the molex will essentially reduce it to about 7V anyway
__________________
  #8
Old 29-12-13, 06:59 PM
mehere's Avatar
OC3D Crew
true I was just thinking of getting away from the reducers and the possible hot spot
__________________
build log
  #9
Old 29-12-13, 07:43 PM
The Guvnor
Its not hot enough to harm, just you know its hot lol.
Modding a molex isnt a bad idea but depends on the connections and the cable. Most will find it easier to smash a reducer in and forget about it.
__________________
  #10
Old 29-12-13, 08:14 PM
Remmy's Avatar
OC3D Elite
Not sure why I've only just thought of doing this now, but if you had fans which happily run at 5V, then you could just swap the red (5V) and yellow (12V) pins on the molex power, and then you have an automatic 5V fan power supply, without the need for any resistors, or any other external things. I do not know if the number of fans you could power would be limited because I don't know if the 5V line provides too small a current (it may even be rated the same as the 12V line, it's something I'll look into), but this is something I'd love to investigate when I get a digital multimeter Anyway when (if) I do get one, I'll be sure to post my findings for everyone on here
__________________
Tags
controller, fans, formula vi, obsidian
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
