Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #11
Old 23-12-13, 10:41 PM
dladdin's Avatar
dladdin dladdin is offline
Member
8350 and the one in my sig
  #12
Old 23-12-13, 10:50 PM
WYP's Avatar
WYP WYP is offline
News Guru
for future reference please do not refer to your sig for specs as that will change over time.
this thread may help some people in the future and a changed sig will confuse future readers.
I recommend the msi 990 GD-65 motherboard that Tripp mentioned before, it is a great price to performance motherboard that will allow you to overclock your future fx 8350.
I recently build my housemate a rig using this motherboard and he is very pleased so far.
__________________
_______________________________
Twitter - @WYP_PC
  #13
Old 24-12-13, 02:01 AM
cooperman's Avatar
cooperman cooperman is offline
OC3D Crew
Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard
http://uk.pcpartpicker.com/part/asus...-m5a99fxpror20
little cheaper Asus M5A97 EVO R2.0
http://uk.pcpartpicker.com/part/asus...rd-m5a97evor20
__________________
i5 4690-Gigabyte Z97P-D3-16Gbs 1866Mhz Kinston HyperX Fury Black-Asus GTX 980 Corsair h80i-sandisk 256gb ultra plus-250gb Intel SSD-WD Blue 500gb-Seasonic M12-620w-Cooler master haf xb.
  #14
Old 24-12-13, 12:10 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
I personally recommend a Asus M5A99FX Pro. I have one ( I realised my sig said evo until recently :s) and its really good as long as you have airflow in your case:
http://www.amazon.co.uk/dp/B0089GN9KU/?tag=pcp0f-21
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #15
Old 24-12-13, 01:45 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
The new Asrock Fatal1ty 990FX Professional caught my eye yesterday very shiny new features including Mini PCI 2.2 slots..... mmm £150 ish
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #16
Old 24-12-13, 06:25 PM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
if you plan on overclocking the 8350 do yourself (and us) a favor please and done skimp on a mobo. Those 8 core fx's need some serious and stable power to oc on.
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #17
Old 24-12-13, 08:32 PM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
I agree with those recommending the 990FX boards. They're a bit more expensive, but they're worth it particularly if you're going overclocking, given that they typically have more beefy heatsinks on the VRMs and more power phases than the lower end AM3+ motherboards.
For instance, I've a Gigabyte 990FXA-UD5 and I managed to get 5.2GHz out of my FX-8350 on it.
It's always best to stretch a bit for your motherboard and not to skimp on it; I've learned this the hard way, I've a cheap POS MSi A55 FM2 motherboard and it makes me want to pull my hair out at times, I'm only sorry I didn't get a higher end A85X one. Whereas my Gigabyte 790FX board which was one of the top end AM3 boards back in 2009 and as a result wasn't exactly cheap is still alive, kicking and rock-solid stable running Debian Linux to this day.
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
  #18
Old 24-12-13, 09:16 PM
dladdin's Avatar
Member
Cool guys thanks
  #19
Old 25-12-13, 12:43 AM
MicroAlex's Avatar
MicroAlex MicroAlex is offline
Newbie
I would recommend an Gigabyte GA-990FXA-UD3 mobo. Personally that was my choice for a build, especially if you want a stealthy base to add colors upon with other parts like RAM, GPU...
Motherboard has plenty of everything, did not saw major drawbacks, unless someone can state otherwise.
Hope it helps.
__________________
To all of the FANS - http://microalex.deviantart.com/art/...sair-347479555
  #20
Old 25-12-13, 12:46 AM
Tripp's Avatar
Tripp Tripp is offline
too many shrooms
Hope it helps.
their are problems with the vrm's on the ud3 board
Tags
am3+, atx, graphics card, motherboard, new build advice
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
