Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 08-12-13, 03:17 PM
QuietOne's Avatar
QuietOne QuietOne is offline
always shouting
Decided to flash my 780 GTX w/ACX
Well imho it wasn't really worth it, my OC before the flash my core was 1224Mhz and RAM was 7002Mhz at 1187mV.
After the flash I could get 1267Mhz core and 7200Mhz RAM at 1200mV and started artifacting above +130Mhz offset. Valley score was 3055 on the flashed Bios with OC which is slightly more than around high 2800 and low 2900 on stock Bios with OC.
If it's under water then it may be worth it but going from 72 degrees max to 80 on air just isn't worth it for me and I really value my GPU and it's lifespan. So it's now back to my backed up stock Bios.
__________________
Wonderful signature by Wraithguard!
Member #045 of the official OC3D OC Club.
  #2
Old 08-12-13, 03:54 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Which bios did you use ? SVL7 or Skyn3ts ?
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
Battle.Net: Dicehunter#2746
  #3
Old 08-12-13, 03:57 PM
tinytomlogan's Avatar
The Guvnor
That is a pointless change mate - better off manually overclocking and then editing the bios if you dont want afterburner or something like that running
The bios change wont magically help you get more out of your card either - silicone lottery
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #4
Old 08-12-13, 04:24 PM
QuietOne's Avatar
always shouting
Dicehunter, I used Skyn3ts ACX custom Bios.
TTL, I've learnt my lesson now, it was mainly out of curiosity and an expensive one if something went wrong, luckily everything seems normal again. I'll stick with 1224Mhz core and 7002Mhz memory. runs everything flawlessly at 1080p so I am waiting for 1440p monitor so my GPU can sweat a bit.
__________________
  #5
Old 08-12-13, 05:54 PM
Dicehunter's Avatar
Resident Newb
The bios mod for the 780 and 780 Ti didn't help me in any way shape or form, For the GTX 680 it helped a lot, I was able to get 1300/3500 gaming and bench stable but only 1200/3200 before the flash.
With the GTX 780 and GTX 780 Ti my overclocks were less for some odd reason, On my EVGA GTX 780 Ti Superclock I have 1250/3800 24/7 game and bench stable but with the bios mod from both SVL7 and Skyn3t I was only able to get 1200/3600.
So to me this means the people who come out with these bios mods either don't really fully know what they are doing OR it is completely random which card the bios will be best on.
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
  #6
Old 08-12-13, 06:12 PM
QuietOne's Avatar
always shouting
I see people supposedly getting 1300+ with titans but running at 1.3v. I was wary of running at 1.21v so I knocked it down to 1.2v but still felt uncomfortable.
I think I will leave it at 1224/3500 which is +100Mhz core and +500Mhz Mem running at 1.18v and below 80 degrees.
__________________
  #7
Old 08-12-13, 06:38 PM
The Guvnor
The 780 Ti I have does 1300 with the boost and no extra volts
You have to remember silicone lottery though, it stands for GPU's more so than CPU's
__________________
  #8
Old 08-12-13, 06:51 PM
Dicehunter's Avatar
Resident Newb
You won the silicon lottery with your 780 Ti because the manufacturer probably cherry picked it and if it's not cherry picked, Then your one lucky bugger
Anything above what you have now is only really useful if your into benchmarking other than that I highly doubt you would notice the difference without running Fraps, Precision X or Afterburner.
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
Tags
780, bios, evga, flash, gtx
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
