Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 04-12-13, 02:45 AM
subliminal_panda's Avatar
subliminal_panda subliminal_panda is offline
Newbie
Help! Can't decide on new mobo
I was able to procure a 4930K for only $195 (about 120 GBP), so I'm jumping into 2011. But I can't decide which motherboard to pair it up with. I am considering the Rampage IV BE, Rampage IV Gene, and the X79-UP4. The black edition is my top pick so far, but I can't seem to find it anywhere (at least not without an enormous mark up). So I began looking at the UP4, which still has the SLI spacing I want. It is lacking in feature set and looks compared with the Rampage, but considerably less expensive. Then I thought, maybe I want to put together a powerhouse mATX system, perhaps in a 350D with that big window. And then I found out that EK is making blocks for the Rampage IV BE. So I am back to square one. Any advice or recommendations?
__________________
Intel i7-4930K | Asus Rampage IV Black Edition | Asus GTX 780 DCII | Corsair Dominator Platinum 2133 16GB | Samsung 840 Pro 256GB | WD Black 1TB | Corsair H100i | Corsair AX860i | Corsair 600T White Edition
  #2
Old 04-12-13, 03:27 AM
NeverBackDown NeverBackDown is online now
AMD Enthusiast
What do you want in your rig? Performance or Aesthetics? Considering you are watercooling then i assume you want both, which then means you will not end up paying a cheap amount. For watercooling its either all or nothing. Don't make any shortcuts as it sort of defeats the purpose of a good looking loop.
  #3
Old 09-12-13, 07:54 AM
Newbie
Thanks for the advice! Ordered the R4BE today. As long as there are no holiday shipping delays, I should have everything up and running by January. I'm planning on switching cases and liquid cooling later, perhaps a spring break project.
__________________
  #4
Old 09-12-13, 07:58 AM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
The RIVE BE is a stunning board, I have just received mine and will start building on Wednesday.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
Tags
350d, 4930k, asus motherboards, gigabyte, water cooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
