Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 12-10-13, 03:52 PM
d3rrial d3rrial is offline
OC3D Crew
AMD CrossFire with Nvidia as PhysX Card?
According to legend I could use an Nvidia card that doesn't drive any displays to do PhysX computations and CUDA calculations while the main screens are driven by an AMD Card.
Has anybody here attempted to do this with two AMD Cards running in a CrossFire configuration + an Nvidia Card in a third PCI-E slot?
The Hardware I plan to use for this is:
ASUS Sabertooth Z87 (C2)
2x AMD R9 290X (CrossFire)
Nvidia GTX 460
I don't need to know it for this exact setup, more generally I just want to know if 2 AMD cards work with one Nvidia card.
__________________
1D3rriAL4Zx4y4ziAxNUzV9YDD8dpkMupW
i7-8700K | 1080Ti | 32GB @ 3000 Vengeance | ASUS Z370 Prime-A | Carbide 540 | RM1000
960 EVO 500GB | 840 EVO 500GB
4.14.13-1-ARCH
  #2
Old 12-10-13, 04:06 PM
PingPangBV PingPangBV is offline
Member
Unless you're running two very slow cards in crossfire or SLi you probably don't need a dedicated physx card as this will just hold things back, guess you could call that a bottleneck. If you were to run two 290x or two 780s you'd just bottleneck the configuration or not get any framerate gain at all most likely.
__________________
Case:900D
Motherboard:MSI Xpower II
CPU: I7 3930K @ 4,6GHz 1,39V
RAM: 16GB Corsair Dominator Platinum 1866MHz
GPU: 2x GTX780
PSU: Corsair AX 1200
SSD: Samsung: 840 PRO 256GB
Tags
amd, crossfire, nvidia, physx
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
