Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 07-10-13, 10:24 PM
R0Y R0Y is offline
Member
Originally Posted by Grey_beard View Post
You are welcome to try it, it does not mean that you cannot do it. I hope you do understand what when I said "From Corsair's standpoint". It is advertised at 1866 with 10-11-10-30 under XMP - Chances are, it'll run with tighter timings.. BUT we cannot say 100% for sure. That is the fine line where I cannot be absolute.
I understand, and thanks for the clarification. I was just wondering if it is AT ALL possible, as in - have others been able to do it.
  #12
Old 07-10-13, 10:35 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
No problem at all
  #13
Old 10-10-13, 11:46 PM
R0Y R0Y is offline
Member
I tested the kit with memtest and the initial experience isn't bad
I used the 4670K and Maximus 6 Hero with my older PSU (Seasonic S12II 520) and graphics card (MSI GTS 250 1GB). I completed a full run of memtest at the default 1333MHz and then enabled the XMP in UEFI and ran that for a while (~65%) then I had to go out. There were no errors at all. Happy
Here are some shots from my test...
Click image for larger version
ID:	6916   Click image for larger version
ID:	6917   Click image for larger version
  #14
Old 11-10-13, 05:33 AM
KING_OF_SAND KING_OF_SAND is offline
OC3D Elite
Originally Posted by Feronix View Post
RAM is pretty much always compatible. As long as it's non-ECC and DDR3.
ECC RAM will still work. Just the ECC part of it wouldn't. I have ECC memory in my server and it uses a 1090t AMD.
  #15
Old 11-10-13, 07:42 AM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Ah thanks, I didn't know that tbh.
Isn't ECC RAM stupidly expensive though?
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #16
Old 11-10-13, 07:47 AM
OC3D Elite
It can be, but it is better to use ECC in a Xeon or Opteron server as those are the only 2 processors that work with ECC.
Tags
1866mhz, corsair, haswell, ram, vengeance
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
