Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 06-10-13, 05:32 PM
R0Y R0Y is offline
Member
Compatibility question
Is this compatible with Haswell? I have a 4670K and Asus MAXIMUS VI HERO.
  #2
Old 06-10-13, 05:47 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
RAM is pretty much always compatible. As long as it's non-ECC and DDR3.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #3
Old 06-10-13, 05:54 PM
R0Y R0Y is offline
Member
I would still like confirmation from a Corsair rep, since their memory finder tool seems pretty useless.
  #4
Old 06-10-13, 05:55 PM
AMD Enthusiast
Yes it is compatible
  #5
Old 06-10-13, 06:13 PM
R0Y R0Y is offline
Member
OK, thanks for the replies. I would have liked to get the "Pro", but that one is nowhere to be seen, and it's been too long to leave the cpu and mobo untested.
  #6
Old 07-10-13, 09:42 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Yes, it is compatible. Both standard Vengeance and Vengeance PRO are compatible with Haswell platform.
  #7
Old 07-10-13, 09:48 PM
R0Y R0Y is offline
Member
Thanks. I'm expecting the kit within the next couple of days.
BTW, can you please tell me if the timings can be tightened a bit? I'm hearing it can't hit the next divider, so...
  #8
Old 07-10-13, 10:08 PM
Grey_beard's Avatar
OC3D Elite
It's spec'd right now (XMP) at 10-11, making it tighter than that may require you to slow down the RAM speed. In short, there is no guarantee, only way to find out is to test it. From Corsair's stand point, we can only guarantee it at 1866Mhz with 10-11-10-30 timings with XMP enabled.
  #9
Old 07-10-13, 10:15 PM
R0Y R0Y is offline
Member
hmmmmm...
  #10
Old 07-10-13, 10:19 PM
Grey_beard's Avatar
OC3D Elite
You are welcome to try it, it does not mean that you cannot do it. I hope you do understand what when I said "From Corsair's standpoint". It is advertised at 1866 with 10-11-10-30 under XMP - Chances are, it'll run with tighter timings.. BUT we cannot say 100% for sure. That is the fine line where I cannot be absolute.
Tags
1866mhz, corsair, haswell, ram, vengeance
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
