Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 19-09-13, 06:14 PM
Yash Yash is offline
Newbie
Exclamation Is this a Motherboard problem? I really don't know (sorry if wrong forum to post in)
Hi, so 2 days ago I received 2 new GPUs and when I got the right drivers they seemed to be working great, but now today when I get home I press the power button on my pc and it turns on for a split second and then turns off again, I tried using each GPU seperately so I guess it has nothing to do with them, and my PSU is a Corsair HX1050 so it can definitely handle them. I tried shaking the case to hear if any loose bits of metal were inside that might have been shorting the motherboard, and even tried reseating the whole system and still the exact same problem, I'm getting pretty stressed out since I need it to do college work and stuff haha, please help
My spec:
i7 980 @4.3 Ghz
Corsair H80
ASUS Rampage III Extreme
12GB Kingston Hyper X Beast 1600MHz
x2 WD Caviar Black 1TB HDD (RAID 0)
x2 MSI NVIDIA GeForce GTX 680 lightning
Corsair HX1050 PSU
  #2
Old 19-09-13, 06:35 PM
Willock's Avatar
Willock Willock is offline
Newbie
What are the indicator LEDs on the board telling you? see which one flashes before it turns off, it might give you an idea of whats going wrong.
If not that, then check that everythings seated okay, it might be you knocked your RAM loose when you were installing the cards.
and remember...
I'm sorry, I've just discovered photoshop xD
__________________
  #3
Old 19-09-13, 06:46 PM
fintekonivel's Avatar
fintekonivel fintekonivel is offline
Newbie
Make sure that everything is connected properly. cables and all. then proceed to bios.
  #4
Old 19-09-13, 07:20 PM
CrazyRussian CrazyRussian is offline
Newbie
you sure you have the CPU power connected?
1.Unplug everything apart from cpu*and cpu power..motheboard power..)
see how it reacts when u try to start it.
2. Remove the cpu and cpu power and start the board, see how it reacts.
3.Find the cmos Jumpuer, reset Cmos.(P.s disconnect PSU power cord)
not sure how bios switch works on your board, but with the system off* power cord still in Powersupply. try pressing Bios Switch Button.
  #5
Old 20-09-13, 12:11 AM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
Do you still have your old GPU? If so, drop that in there since you know it worked. If it fires up with no problem then its a problem with your new GPU's. I know that sounds unlikely but your rig worked fine before you stuck the new GTX680's in there.
Could be a bad stick of RAM as well. You could always try booting with just 1 stick at a time and see if that helps any.
__________________
AMD R5 1600X @ 4.0 GHz ••• Asus ROG Strix X370-F ••• Corsair H110i
Corsair 500R ••• EVGA Supernova G3 750 ••• Corsair Vengeance 16GB
Western Digital Caviar Black 1TB x2 ••• Nvidia RTX 2070 FE
Samsung 840 Evo 250GB ••• Acer Predator XB272 @ 240 Hz
Logitech G-Pro TKL ••• Logitech G MX518
  #6
Old 20-09-13, 04:15 AM
AMD Enthusiast
Did overclock anything? Might not be stable and was only stable enough to get you into windows but thats it.
Tags
help me, motherboard, problem, short circuit, troubleshooting
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
