Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #11
Old 17-08-13, 01:28 PM
remember300 remember300 is offline
OC3D Elite
Glad it helped. And thats fair enough you just did not need a massive supply. And with the 650 you have room for sli even 780's although id probs go a little higher for longevity.
__________________
  #12
Old 05-09-13, 02:03 PM
Mr.a2008 Mr.a2008 is offline
Newbie
Thanks for that. I may consider a sli setup later on but at the moment since funds are tight I will stick with a single graphics.
  #13
Old 05-09-13, 03:28 PM
kilobravo kilobravo is offline
OC3D Elite
Send a message via MSN to kilobravo
System powerdraw will increase significantly when you oc amd 8-core CPU's.
Something like 250w or more powerdraw if you try to have a go at 5ghz oc.
Its worth considering i think.
__________________
  #14
Old 05-09-13, 08:55 PM
Newbie
Well I wont be oc for a while till I break it in and have some more funds for when I absolutely kill it! Hehe
  #15
Old 05-09-13, 09:03 PM
OC3D Elite
That seems quite a lot of power for an OC, but ive never played with AMD cpus much. Still i think MrA is fine with 550W or 600W, to cover all bases and ill hopefully be folding again soon, once i move
__________________
Tags
build help, power supply, psu
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
