Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 23-06-13, 12:39 PM
JackMcLaughlan JackMcLaughlan is offline
Newbie
Question Motherboard Power Confusion
So I recently bought a GTX 770 and now I want to upgrade to Haswell as I am currently running an AMD APU. My PSU is a Corsair HX650, the problem I have is that on many of the mid-high end Z87 motherboards there is, instead of a single 8-pin, an 8 and a 4 or 2 8-pin power connectors, but my PSU only has 1 8-pin CPU power connector.
So my question is; Can I run a mid-high end Z87 motherboard, an 'MSI MPOWER MAX' for example, with only one of the conectors (and the 24-pin obviously) being used?
Many thanks.
  #2
Old 23-06-13, 12:49 PM
Netroxen's Avatar
Netroxen Netroxen is offline
Member
Send a message via Skype™ to Netroxen
Not having all the power sockets connected will result in stability issues and the motherboard may not even post at startup without doing so. I'm pretty sure you can buy a Molex to 8 pin power adapter, or you may even be able to daisy-chain off the main ATX connector.
However I wouldn't advise running the system without all the connectors being used.
__________________
Never argue with an idiot, they drag you down to their level and beat you with experience. || Once more into the fray, to the last good fight I'll ever know - Live and die on this day, live and die on this day.
  #3
Old 23-06-13, 01:24 PM
WillSK's Avatar
WillSK WillSK is offline
OC3D Elite
Send a message via Skype™ to WillSK
I may be wrong but i'm pretty sure the extra cpu 8 pin is for extreme overclocking and not a necessity for the average user. I'd wait for someone else to clarify this though.
I wouldn't consider MPower Max a "Mid high end board" though, i'd say it's well up there with the higher end boards as only the Xpower is more expensive
__________________
My Rig : Fractal S2 Case, ASUS Crosshair VIII Hero, Ryzen 3800X, Corsair H115i Platinum, MSI GeForce RTX 2080 GAMING X TRIO, 32 Gb Team Pro Dark RAM 3200Mhz, Samsung 970 EVO SSD, Samsung 850 Pro 500GB SSD, Seasonic Prime Ultra Titanium
  #4
Old 23-06-13, 02:42 PM
Newbie
Okay, thanks for the help. when i said mid-high end i meant in price, as there are others mobos over double the price of the MPOWER MAX.
I think I will go with the ASRock Z87 PROFESSIONAL because its around the same price and it has 1 8-pin and essentially all the same features.
  #5
Old 23-06-13, 02:48 PM
iBeInspire iBeInspire is offline
OC3D Elite
I'm pretty sure you can leave the 2nd 8-pin/4-pin alone on most boards, in the same way you can leave the 6-pin for the PCI-e slots. It's just meant to provide extra power but isn't necessary.
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
  #6
Old 23-06-13, 02:51 PM
WillSK's Avatar
OC3D Elite
Have you looked at gigabyte's Z87 offering. Some great boards in there at all price ranges. Also consider the MSi Z87 GD65 gaming
__________________
Tags
connection, motherboard, power, problem, z87
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
