Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 15-06-13, 07:41 AM
TheDigitalRealm TheDigitalRealm is offline
Newbie
Best GPU config for £600?
Right, pretty self explanatory, building my first gaming rig, my GPU budget is £600 and I will initially be gaming on a 120Hz 1080p monitor. By Christmas I'll probably have moved to a 2560 x 1440 monitor.
Any suggestions on a config that would allow me to play games maxed out at decent frame rates?
And: Yes, the board I'm planning on getting will be at least a 2 way CF/SLI capable.
  #2
Old 15-06-13, 10:08 AM
Spiderz's Avatar
Spiderz Spiderz is offline
OC3D Crew
GPU budget of £600? GTX 770 or 780 seems to be the way to go. 780 if you really want to push it with the 1440p screen.
__________________
Current Rig:
NZXT H440 White, Corsair RM550x , AMD Ryzen 5 1600 w/ Cryorig H5 Universal, MSI GTX 1660 ARMOUR OC, 1TB HDD, MSI x370 Carbon Gaming Pro motherboard, 16GB RAM, Samsung 840 Evo 250GB
  #3
Old 15-06-13, 10:38 AM
antihero's Avatar
antihero antihero is offline
Member
Well, you'd rather need two 780s to get playable frame rates in 1440p. I think a lot of people underestimate how big of a hit resolution takes on your performance. But to be fair, all hi-res benchmarks are with anti-aliasing turned to max, which is arguably the most GPU intensive setting. A single OC 780 should be enough to play most games maxed out @ 60 fps in 1080p ( except for games like Crysis 3 ). However, if you do choose to get a WQHD monitor, you need to invest more into graphics - get a second card, maybe put them under water.
  #4
Old 15-06-13, 10:40 AM
Silver Sparrow's Avatar
Silver Sparrow Silver Sparrow is offline
Member
Depends really. If you need it right now, I'd go for the GTX 780. No hassle, fast as hell and looks the gonads. If you can hold out and wait I'd see what AMD will show with their 8000 series desktop GPU's [not the OEM rebrand gpu's]. The 8970 looks promising should the rumourmill be somewhat accurate and be within your budget. Release date speculated for q3 this year.
__________________
F4TG1RL: i5 3570k wc | MSI Z77 GD65 | R9 290 Xfirewc | 8GB DDR3 1600 | Samsung 830 250GB | Fractal Arc Midi R2 | CM V1000
wc: GPU EK R9-290 FC Acetal & Backplate | CPU EK-Supreme LTX - Nickel CSQ | Fittings Monsoon Black Chrome & Primochill PF LRT Onyx Black | Pump XSPC Nylon Dual Bay Reservoir & Laing D5 Vario | Radiator Alphacool NexXxoS Monsta 240
  #5
Old 15-06-13, 11:45 AM
theDTP theDTP is offline
OC3D Crew
780 is a terrible card in a price/performance ratio. Rather spend a little extra on 770 sli. You would see 50% more performance over the 780 for about £90 more which would be £40 over budget but should even run Crysis 3 at 60fps on 1440p
__________________
Intel i5 4670K | GIGABYTE Aorus 1080Ti Xtreme| 16GB Corsair Vengeance Pro | Gigabyte Z87X-UD4H
OCZ ZT 750W | Samsung 840 EVO 500GB | CM Storm Trooper | ASUS PG278Q | Corsair K95 RGB | Corsair M65 | H100i | WD My Book 2TB
  #6
Old 16-06-13, 02:07 PM
Zaim Zaim is offline
Member
If you're moving to 1440p I'd be tempted to pick up two 4GB GTX 770's tbh. If you want a Single GPU then the best you're going to get for £600 is a GTX 780, as mentioned above the price/performance ratio is not good compared to the 770.
__________________
CPU:Intel I7 3770K|CPU Cooler:Noctua NH-D14|RAM:16GB Corsair Vengeance White LP |MB:ASUS P8Z68-V Pro/Gen3|GPU:Asus GTX 980 Strix|PSU: Corsair AX750|Hard Drives: 2xCorsair Force GS 240GB SSD, WD 2x2TB|OS: Windows 8.1|Sound Card: Xonar HDAV|Speakers:Speakers:Sony STR-DN850+Yamaha Speakers+Tannoy TS2.10|Corsair K95 Corsair M95|
  #7
Old 16-06-13, 03:37 PM
OC3D Crew
I've just looked at prices and they are on sale for as low as £350 for the Palit Jetstream. £370 for the Zotac and a whopping £450 for the Phantom! I see no reason for people to even consider the 2GB version.
__________________
  #8
Old 17-06-13, 06:59 PM
{SAS}TB {SAS}TB is offline
Newbie
7970 crossfire? Under budget, 3GB of VRAM of plenty of grunt to play everything maxed
  #9
Old 17-06-13, 07:58 PM
Member
That's an option, i didn't recommend that due to the frame time/rate issue people have been complaining about.
__________________
  #10
Old 17-06-13, 08:05 PM
Newbie
I've read the article and not personally experienced the issue with 2 or 3 cards
Definitely no (to me) noticeable difference between sli, tri-sli, crossfire or tri-fire
7970s are still awesome cards, especially with current price point and second hand sales
Tags
amd, gpu, graphics card, nvidia, sli
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
