Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #1
Old 06-06-13, 09:29 PM
murdergames murdergames is offline
Newbie
Seasonic X-850 watt substance leakage
I received my Seasonic power supply sometime in december 2012 and I have had no problems with it until today (6th of june 2013) where when cleaning my case of dust I noticed some kind of liquid had leaked on some of the internals of the power supply and dried up. I am no expert but this started to ring alarm bells with me as I had looked at the back of my powersupply many times and had never seen this 'leakage' before. I am running everything at stock and the only other problems I have had were the occasional blue screening caused by audio issues with my onboard sound chip not agreeing with battlefield 3.
Here are some pictures of the liquid sorry about the quality/focus.
What should I do?
Should I return it as this power supply has a five year warrenty?
Is this a common problem?
  #2
Old 06-06-13, 09:39 PM
Kei's Avatar
Kei Kei is offline
Advanced Member
That is normal. It is silicone-glue and it is there to keep the components from bending and shorting out. It's also used to minimise coil vibration, aka, coil whine. I haven't taken apart a psu that hasn't had that stuff in it. For reference, if a capacitor leaks:
1. What comes out isn't pure white
2. They don't leak anywhere near as much as that
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ 32GB 8 Pack 3200C14 ⁞⁞ Enthoo Primo
Seasonic Prime 750W ⁞⁞ Polaris 961 256GB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD Se 4TB & 1TB x2 ⁞⁞ Samsung C27HG70 + Dell 2408WFP
Ducky Shine 5 ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B ⁞⁞ AKG K601 ⁞⁞ Beyer DT770
  #3
Old 06-06-13, 09:43 PM
Newbie
So this is normal phew.
It was just the fact that it didn't appear for months and all of a sudden it was there.
Does this happen with all power supplies or is it just a feature of some?
Thanks for the help Kei.
  #4
Old 07-06-13, 01:44 AM
Goldskis45 Goldskis45 is offline
OC3D Crew
Yeah, I've seen that before. Never knew exactly what it was but I figured it was a glue of some sort. It has never caused issues for me.
Tags
power supply, problem
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
