Thread Tools Display Modes
  #1
Old 05-06-13, 11:22 AM
Jaanbo Jaanbo is offline
Newbie
Opinions on first build? Fan advice also
So this is my first time actually posting on this forum, was just wondering if i could get some advice on the build i currently intend to go ahead with
Build:
Gigabyte GA-Z87-D3HP
Intel i7 4770K
Corsair Vengeance 16gb 4x4 (1600MHz, 9-9-9-24)
EVGA GTX 660 2gb FTW Edition (maybe the 760 if it comes out soon enough)
OCZ ZS Series 650w PSU 80+ Bronze
Western Digital 1Tb HDD
All of this inside of a Cooler Master HAF XB
About the fans, the case I would be getting comes with 2 120mm stock fans for the front of the case which i intended to keep to cut costs, that leaves space for 4 more fans in the form of a 200mm, 120mm and 2x80mm. For the 120mm i intended to go with some form of Gentle Typhoon, and the two 80mm fans just some cheap artic ones. The main issue I am having is finding a good black 200mm fan as the only I really have any faith in is the Cooler Master MegaFlow Black, which I cannot find anywhere in the UK?
Any advice, help or comments are greatly appreciated, thanks.
  #2
Old 05-06-13, 12:02 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
The case is excellent. Good choice!
for the 80mm fans, it is important to get quiet ones, in my experience these are the best. I've replaced my old antec 80mm fan (suprisingly powerful but made my pc sound like a server :C ) with this:
http://www.scan.co.uk/products/80mm-...ent-wings-pure
for the 200mm fan, this is good for what you want, you can get a blue one instead if you want:
http://www.scan.co.uk/products/200mm...n-with-red-led
Also, I'd get the i5 and use the spare cash to go for a SSD. Trust me, SSDs are really, really good and not worth overlooking.
-edit- Are you planning on getting a CPU cooler?
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #3
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
What do you want to use your build for? For gaming you'd be better off with an i5 4670k and spend the rest on a better GPU. If you're not very much into gaming, this set-up is fine.
Buy a decent power supply by Corsair, XFX, Seasonic, NZXT, etc. OCZ is not the most reliable brand. Another thing to consider is to get a 2x8GB RAM, so you have the ability to expand more easily later on.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #4
Old 05-06-13, 12:13 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Gotta agree with Feronix get a better Psu the rest sounds ok
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #5
Old 05-06-13, 12:19 PM
Newbie
cheers people just wondering then would the i5 4670K be good enough when it comes to encoding and rendering and the like? because i would be gaming but also probably making youtube videos.
Also about the RAM, i wanted the 4 sticks mainly for appearance if im honest, do i really need space for additional RAM when 16Gb is already overkill??
Yeah i forgot to mention the CPU Cooler, the BeQuiet Shadow Rock Pro SR1 comes free with the motherboard
Again, thanks for the advice here
  #6
Old 05-06-13, 12:35 PM
BradleyW-H's Avatar
BradleyW-H BradleyW-H is offline
Member
If you're only doing light rendering every so often then you are best of saving some money and going for the i5 4670K. If you're going to be rendering videos every day and putting your system under a lot of load then you will have to go for the i7 4770k.
16GB Ram is fine. If i were you though i would get two 8 GB sticks because then in the future if you find 16GB isn't cutting it any more then you can always upgrade your RAM.
The CPU cooler is fine and actually looks really nice in my opinion. They are also really easy and simple to install. So no complex mounting systems to fiddle about with for hours.
Although OCZ are good and I have one of their power supplies. They aren't the highest recommended Maybe go with a corsair TX, HX, AX, or maybe even the GS800. They are all really good.
I would also try and squeeze some sort of SSD in there. Even if its a last gen one. Like a 830 series from samsung. I recomend any around the 128GB mark as thats enough space for a good amount of programs and your OS. You can then use you mechanical HDD as storage for all of your music, games and videos ETC.
Hope that helps and GOOD luck.
__________________
Gaming rig || AMD FX-8150 || Corsair H100 || MSI GTX 680 || ASUS M5A97 PRO || OCZ 700W PSU || Samsung 840 EVO || ASUS XONAR D2X || Cooler Master HAF-X || Logitech G710+ Keyboard || Logitech G402 Mouse || Sennheiser PC350SE ||
  #7
Old 05-06-13, 12:43 PM
Newbie
I saw that 200mm fan thats the one i was talking about, but i wanted the fan in black which i can only find in the US
  #8
Old 05-06-13, 12:46 PM
barnsley's Avatar
born in a.....
If you're going to do youtube videos, you need an ssd as well as an HDD. It makes things much more easy .
__________________
  #9
Old 05-06-13, 01:32 PM
Newbie
right i have found a SanDisk 128gb SSD for like £65, i know it helps actually load everything up quicker but is that the actual only noticeable benefit?
Also i kind of want the 200m Bitfenix Spectre Pro Black fan, i know they're really good but someone said that they are not good mounted horizontally is this true? because it would be my top exhaust.
Thanks for the help though so far guys, think i've revised my decision down to this so far..
Intel i5 4670k
Gigabyte GA-Z87-D3HP Motherboard
Corsair Vengeance 16gb 4x4 1600MHz RAM (9-9-9-24)
EVGA 660 or 760
Corsair Builder Series CXM Modular PSU 600w 80+ Bronze
SanDisk 128gb SSD
2x BeQuiet! Shadow Wings 80mm Low Speed Fans
1x Gentle Typhoon (1450 or 1850)
200mm Bitfenix Spectre Pro 200m Fan (Black)
(Case Comes with 2x 120mm Cooler Master Fans for intake)
Sorted?
  #10
Old 05-06-13, 01:57 PM
BradleyW-H's Avatar
Member
That SSD is fine yea. Not only does it help you boot up faster, open programs faster, shutdown faster, transfer data faster. It also helps you with overall better system responsiveness. I also still recommend that you go with 2x8GB sticks.
Other than that its fine.
__________________
Tags
advice needed, components, fans, first build
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
