Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 03-06-13, 08:44 PM
BenneMus BenneMus is offline
Newbie
GTX 780: Can you change the lights?
Hey guys, I am going to be building a new pc soon, and the theme is a black and red color combo. But since I am going with two 780's and they light up green on the side I was wondering if you can change that in a program, or if you have to mod the cards to change it.
thanks!
  #2
Old 03-06-13, 08:47 PM
Cru's Avatar
Cru Cru is offline
OC3D Elite
you can't change the color, would require modding but that's not gonna be easy with that cooler
  #3
Old 03-06-13, 08:56 PM
Newbie
Thanks man.
Do you have a suggestion on how to do it?
  #4
Old 03-06-13, 08:59 PM
Cru's Avatar
Cru Cru is offline
OC3D Elite
no sorry, don't have the waterblocks on my 780s yet so can't really tell how that cooler looks from the inside.
in the block fitting guide for the titan TTL did it looked like it's not easy
  #5
Old 03-06-13, 09:04 PM
Newbie
Okay, I'll look into it Thanks
  #6
Old 03-06-13, 09:05 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
You *might* be able to solder in some different LEDs but then you'd still have the green plastic on there so you would have to remove that and find a way to replace it with red acrylic.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #7
Old 03-06-13, 09:54 PM
remember300 remember300 is offline
OC3D Elite
it would look better with a clear acryllic, and they will most likely be SM LED's. not fun to solder with.
__________________
  #8
Old 03-06-13, 10:19 PM
Feronix's Avatar
OC3D Elite
Probably, but that would look weird if the lights (pc) were turned off. Or even if it's on, if the LEDs are located right behind the acrylic and not to the sides, for example.
__________________
~Rick
  #9
Old 03-06-13, 10:20 PM
OC3D Elite
you can get wide angle SMLED's but yeah maybe the geforce is like a light bar
__________________
  #10
Old 05-06-13, 08:04 PM
Vlada011's Avatar
Vlada011 Vlada011 is offline
Advanced Member
I have red and black combo and I will choose this...
But I leave PC dark, only led lights with hardware and sound card shine.
That is enough to see everything inside, model, shape, but not too shine...
__________________
Intel® i7-3770K (4.5GHz) + CORSAIR H100
EVGA Z77 FTW
EVGA GTX780Ti 3GB K|NGP|N Classified #33
CORSAIR Dominator Platinum 1866MHz (2x4G
CORSAIR Force GT 120/WD500AAKS
EVGA NEX1500 Classified/Seasonic X-750
CORSAIR Obsidian 650D
Logitech G510/G700/C310/ Samsung P2450H
Tags
gtx 780, lights, mod
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
