Go Back   OC3D Forums > [OC3D] Processors & Platforms > Memory
Thread Tools Display Modes
  #11
Old 03-06-13, 03:51 AM
Mark3Max Mark3Max is offline
OC3D Crew
I'm still a bit of a newbie on memory , but are you sure the memory is compatible with that motherboard?
According to the specs on that board 1866 and above are overclocked.
How did you setup the memory? Manually or XMP ?
And make sure you have them in the right slots.
__________________
Corsair 650D, MSI Z77A-GD65 , I7-3770k, Corsair H100i w/sp120 QE ,G.Skill Ares 16gb 2133 c9, Asus Blu-Ray Burner, Asus Xonar STX ,Corsair Neutron GTX 240gb ,W.D. black 1TB ,Seagate 3TB, MSI GTX 680 Lightning, Corsair AX760i ,Case Fans : Front : CM 200 blue,Rear : Corsair AF 120 PE , Klipsch 2.1 , Sennheiser HD650 , 2 x Samsung 23" 1080p , Logitech G710+
  #12
Old 03-06-13, 09:56 AM
theDTP theDTP is offline
OC3D Crew
I use to have the 212 evo with SP120s and I can confirm they fit and work very nice. Try and get your hands on some more ram and see how that works for a few days, alternatively you could just go ahead and try more volts on the ram and a little on the cpu, 1.65v maximum for the ram, just go up a little at a time until you stop BSOD (not benchmark BSOD) and if this doesn't fix your problem then try to loosen the timings a little and remember, the memory controller on this CPU is rated at 1600MHz and any more is considered an overclock. I could go and buy some 2800MHz ram but on my CPU it's already proven to me that the most it will be stable at is 1866MHz, just because your ram is rated at 2133MHz this does not mean your CPU will be able to use it. Just persevere and try what has been said and good luck, also have fun
As for prime95, people have tested for much longer than 12 hours and BSOD opening a new browser tab.
If you need help with changing volts and timings there will be something on this forum, I can't direct you just yet as I am on my phone.
__________________
Intel i5 4670K | GIGABYTE Aorus 1080Ti Xtreme| 16GB Corsair Vengeance Pro | Gigabyte Z87X-UD4H
OCZ ZT 750W | Samsung 840 EVO 500GB | CM Storm Trooper | ASUS PG278Q | Corsair K95 RGB | Corsair M65 | H100i | WD My Book 2TB
  #13
Old 07-06-13, 09:24 PM
OC3D Crew
Try new ram, I just got a z87 motherboard and 4670K and while I was there I bought 16GB Corsair Vengeance Pro. Just tested the Corsair Vengeance Pro in my current rig (not fitting the new mobo and CPU until Sunday) and good lord it booted 2133MHz instantly! I recommend trying new ram, I've been running on faulty ram for over 12 months!
__________________
  #14
Old 13-06-13, 10:02 AM
johnnyme johnnyme is offline
Newbie
so far i just sold my old asrock and replace it for new version of Hi-Fi A55S3 ver. 6.1 thats biostar.. speed is literally fine and well progression! =)
  #15
Old 19-06-13, 06:50 PM
Larocka Larocka is offline
Newbie
Ok, so I decided to take a gamble and try new ram, some of that new corsair vengence ram 2133 (16 gb) works fine, got the old ram replaced under warranty.
so it was the ram, thanks for your help guys.
  #16
Old 19-06-13, 08:57 PM
OC3D Crew
This is good news! Glad it was only the ram that was the problem and that you have your old stuff replaced
__________________
Tags
2133, ram
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
