Go Back   OC3D Forums > [OC3D] Graphics & Displays > Screens and Displays
Thread Tools Display Modes
  #1
Old 21-05-13, 08:25 PM
dalewakelin's Avatar
dalewakelin dalewakelin is offline
OC3D Elite
Send a message via Skype™ to dalewakelin
laptop monitor coversion
Hello, i am going to be converting a laptop monitor into a desktop monitor. I will be using an old psu to power it, i will short it and use 5v. I will also be changing the weird laptop connector to dvi. I don't know if i will make a bezel for it but i will concentrate on making it work for now. 40 pins to turn into 24.
Parts:
LG and Phillips laptop screen LP154W01
DVI to VGA converter (to be ripped apart)
Hipro 560w PSU
Pictures:
__________________
  #2
Old 21-05-13, 09:03 PM
SavageCupcake's Avatar
SavageCupcake SavageCupcake is offline
OC3D Elite
Are you sure this'll work? A friend of mine tried it and it turned out the laptop ports were properiatary and he couldnt get it to work. good luck though
__________________
Main PC
Intel core I5 4670k--16gb Kingston hyperX--Asus z97a pro gamer--MSI r9 380 4gb--Corsair RM650--Noctua NH-D14--Cooler master cm 690 2 b&w--120gb 840 EVO--2x 2tb WD green
  #3
Old 21-05-13, 09:44 PM
OC3D Elite
I have no idea if this will work or not haha
__________________
  #4
Old 21-05-13, 09:53 PM
OC3D Elite
Fair enough, hope it does but wouldn't suprise me if they pull some sneaky shizz like that.
__________________
Main PC
Tags
conversion, convertor, laptop, monitor, screen
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
