Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 05-05-13, 10:26 AM
Youssifm Youssifm is offline
Newbie
GTX 790 vs 3 way GTX 780 for Nvidia surround
Hey Everybody!
I was looking to build a new pc when haswell and the gtx 700 series comes out, but I can't decide on what I want to buy. I plan on gaming in Nvidia surround.
So here is my question. ASSUMING the 700 series perform similar to the 600 series would 3 GTX 780s offer a significant fps increase from a GTX 790?
The obvious answer is 3 GTX 780s but I think the scaling from 2 to 3 GPUs is not a significant jump in performance. Maybe only 10-15 fps. What do you guys think?
-Youssif
  #2
Old 05-05-13, 10:51 AM
WillSK's Avatar
WillSK WillSK is offline
OC3D Elite
Send a message via Skype™ to WillSK
literally no point asking this question since none of the cards are out yet so we don't really know. However assuming what you say then yes 3 780s is likely to be better than 1 790 due to having an extra GPU
__________________
My Rig : Fractal S2 Case, ASUS Crosshair VIII Hero, Ryzen 3800X, Corsair H115i Platinum, MSI GeForce RTX 2080 GAMING X TRIO, 32 Gb Team Pro Dark RAM 3200Mhz, Samsung 970 EVO SSD, Samsung 850 Pro 500GB SSD, Seasonic Prime Ultra Titanium
  #3
Old 05-05-13, 11:05 AM
SavageCupcake's Avatar
SavageCupcake SavageCupcake is offline
OC3D Elite
If it's anything like previous generations then the 790 will be 2x underclocked 780's, so the 780's would probably be better but as you said scaling past 2 cards is pretty crap.
Just wait for the cards to come out and decide then
__________________
Main PC
Intel core I5 4670k--16gb Kingston hyperX--Asus z97a pro gamer--MSI r9 380 4gb--Corsair RM650--Noctua NH-D14--Cooler master cm 690 2 b&w--120gb 840 EVO--2x 2tb WD green
  #4
Old 05-05-13, 05:43 PM
seumasbeathan seumasbeathan is offline
Banned
I really do not see why you would want 3 x 780's? Also there 790 will not come out for quite a while after the 780's is released.
  #5
Old 05-05-13, 06:00 PM
alienware alienware is offline
Banned
Send a message via MSN to alienware
I don't think there will be a 790. If there is then it's going to need some seriously hefty cooling.
3 of any graphics card is never worth it because games simply don't support it and it can make performance worse than using two cards.
If one day the consoles end up with 4 graphics cards or 3 graphics cards it might just work but for now you're better off sticking with two.
  #6
Old 05-05-13, 10:16 PM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
another thing of note. Do we know yet the pci-e bandwidth limitations on haswell yet??? If its anything like current offerings you may get 2 @ x16 but adding a third card would knock it to x8 x8 x4 but some boards will have like mine an additional chip that allows for more bandwidth.
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #7
Old 06-05-13, 12:12 AM
Mark3Max Mark3Max is offline
OC3D Crew
Hi Youssifm and welcome to the OC3D forums,
I think your dealing with too many unknowns, the motherboards, processors and graphics cards have not been released yet. No one has done any final testing of any of them yet to even know what their capable of. If this is really what you want to do , I would wait and read/watch a bunch of reviews before deciding to spend all that money.
__________________
Corsair 650D, MSI Z77A-GD65 , I7-3770k, Corsair H100i w/sp120 QE ,G.Skill Ares 16gb 2133 c9, Asus Blu-Ray Burner, Asus Xonar STX ,Corsair Neutron GTX 240gb ,W.D. black 1TB ,Seagate 3TB, MSI GTX 680 Lightning, Corsair AX760i ,Case Fans : Front : CM 200 blue,Rear : Corsair AF 120 PE , Klipsch 2.1 , Sennheiser HD650 , 2 x Samsung 23" 1080p , Logitech G710+
  #8
Old 06-05-13, 12:26 AM
S_I_N's Avatar
OC3D Elite
agreed and posting what most see as a useless thread because of the above statement. To many unknown variables to even guess so its pointless to ask these kind of questions ......unless your just trying to pad your post count lol
__________________
Intel 7700K
Samsung 850 EVO 1TB
Tags
3 way sli, 790, gpu scaling, gtx 700, sli
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
