Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #11
Old 01-04-13, 02:21 PM
equk's Avatar
equk equk is offline
OC3D Elite
As the 7950 keeps up with the GTX680 when overclocked (check toms review of the Club 3D 7950 Royal King) , I'd go for the 7950
As said above, unless you have a specific requirement for CUDA or Nvidia the 7950 is pretty amazing for the price when overclocked.
Also most CUDA apps now support OpenCL (eg: adobe photoshop, sony vegas, powerdvd, gimp)
__________________
i5-2500K @ 4.8Ghz | 16G DDR3 | P8Z68-V GEN3 | Archlinux | Ryzen 7 Soon?
  #12
Old 01-04-13, 03:21 PM
iBeInspire iBeInspire is offline
OC3D Elite
Although the cooler might not be great on that 7950, the core will still be faster stock vs stock than a 660 ti... With overclocking (normally you'll hit stability issues before you hit temp issues with GPUs) that will only go further
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
  #13
Old 01-04-13, 03:25 PM
Cs342 Cs342 is offline
Newbie
If this helps at all, I'm running 2 1680x1050 monitors (only gaming on one). Probably won't need the 3GB of memory the 7950 has.
  #14
Old 01-04-13, 03:27 PM
SeekaX SeekaX is offline
OC3D Elite
haven't we had the exact same question just yesterday?
7950
/end
  #15
Old 01-04-13, 04:29 PM
alienware alienware is offline
Banned
Send a message via MSN to alienware
7950
/end
OP has stated he uses CUDA accelerated apps so the 660ti may be the better choice.
  #16
Old 01-04-13, 08:35 PM
OC3D Elite
well then the question is kinda pointless, isn't it?
Tags
660 ti, 7950, graphics cards, gtx, radeon
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
