Thread Tools Display Modes
  #11
Old 25-03-13, 12:39 PM
Mark3Max Mark3Max is offline
OC3D Crew
You do good work dude , it almost looks store bought.
Great job.
__________________
Corsair 650D, MSI Z77A-GD65 , I7-3770k, Corsair H100i w/sp120 QE ,G.Skill Ares 16gb 2133 c9, Asus Blu-Ray Burner, Asus Xonar STX ,Corsair Neutron GTX 240gb ,W.D. black 1TB ,Seagate 3TB, MSI GTX 680 Lightning, Corsair AX760i ,Case Fans : Front : CM 200 blue,Rear : Corsair AF 120 PE , Klipsch 2.1 , Sennheiser HD650 , 2 x Samsung 23" 1080p , Logitech G710+
  #12
Old 25-03-13, 08:38 PM
C4B's Avatar
C4B C4B is offline
Newbie
Send a message via Skype™ to C4B
Great job.
Oh thank you! Nice to hear!
Got some work done today again.
HCP here on the forum thought I should make a harddrive bay in the same design as the case. So heres the result.
Which one of the harddrive bays do you like? I cant decide really.
  #13
Old 25-03-13, 11:32 PM
wassupdoc's Avatar
wassupdoc wassupdoc is offline
OC3D Elite
1st one and I LOVE the design, it's so simple and elegant it really is a joy to look at
__________________
"Entertaining by default"
  #14
Old 26-03-13, 11:10 PM
C4B's Avatar
C4B C4B is offline
Newbie
Thank you! But Im sorry to say that I went with the second design.
Made new cutouts of the second design, this time for three harddrives. Sanded down the edges and ofcourse painted it white. I think Ill go with this design actually, I asked around what people thinks and its 50/50. But when the case has this round, smooth design it feels better with a similar harddrive bay instead of something with raw edges.
Second design rev 2:
In the case
It kinda looks like a smaller version of the case. Ill go with this one!
  #15
Old 27-03-13, 04:43 AM
badtaylorx's Avatar
badtaylorx badtaylorx is offline
Advanced Member
great job on the curved plexi....thats not easy to do right!!! i had the 3-ion-t i deluxe too....wasnt a bad lil board for what it was....mine was mounted in a NES tho...
__________________
http://3dmark.com/3dm11/2716743 highest 2500k+560Ti SLI TO DATE!!!
  #16
Old 27-03-13, 07:59 PM
C4B's Avatar
C4B C4B is offline
Newbie
Thanks! Yes it works good for movies and music, but got kinda slow when I was checking internet and so on. Oh NES cases, love em!
  #17
Old 27-03-13, 10:37 PM
Lystfiskern Lystfiskern is offline
OC3D Crew
Nice little system u made there C4B
Eager to see your other build....
__________________
[SIZE="2"][FONT="Book Antiqua"]Fractal Design Define R5W White / Corsair AX760i[/ EVGA Z97 FTW / Intel® Core i7-4790K / 32GB Kingston HyperX Savage 2400Mhz / Samsung 850 Pro 250Gb/Corsair Force Series GT 240Gb / HGST 4Tb / Seagate Barracuda 3Tb / MSI GTX970 Gaming / Corsair H100GTX - Corsair SP120QE / Dell Ultrasharp U2410/ Corsair AF140QEx2 Front / Corsair AF120QEx2 Bottom/Back
  #18
Old 27-03-13, 10:40 PM
C4B's Avatar
C4B C4B is offline
Newbie
Ill start a project log for that as soon as this one is 100% finished.
  #19
Old 03-04-13, 08:52 PM
C4B's Avatar
C4B C4B is offline
Newbie
Hey!
My new motherboard is here! Finally, without the i/o shield though so I had to get a new one from ebay. However, I installed the new mobo and this time I need to use a picopsu so some sleeving was done. Now you can see my harddrivebay in action!
Whats in here???
Open it up and tada!
Goodlooking cooler!
Im pretty satisfied with this harddrivebay.
I cant decide if Im going to go like this, with sleeved cables, or hide them all under the harddrivebay and motherboard so only the sata cables is showing. What do you think?
Cheers!
Johan Nyman
  #20
Old 03-04-13, 09:06 PM
OC3D Crew
I think U would end up with a more uniform look with all braided white/blue cables. However i think the actual routing of the cables is good as is.
__________________
Tags
acrylic, curv3d, mini-itx, scratchbuild, white
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
