Thread Tools Display Modes
  #11
Old 25-03-13, 07:32 AM
JayCobs's Avatar
JayCobs JayCobs is offline
Member
Location: Where it's hot in the summer and cold in the winter
Originally Posted by alpenwasser View Post
Almost, all it takes is a slight whiff of air. Maybe blow on it once an hour to exchange it
It really is an awesome case, yeah. Very happy with it
I'll make sure to provide some detail pics when I do my build log.
Excellent. Can't wait for the build log. Any ideas on what color cable sleeving I should use? I'm thinking orange or grey.
__________________
Preventively pessimistic.
Projekt Suma Kuhl 2013 (ended)
http://forum.overclock3d.net/showthr...Suma+Kuhl+2013
Tha Leviathan build in progress...
http://forum.overclock3d.net/showthread.php?t=56390
  #12
Old 25-03-13, 08:01 AM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Oh yeah, forgot about that question
I'm trying to picture a black M/B tray with orange cables. Black/orange is a great combo imho, but I'm not sure how the chrome of the GPU backplates will mix with orange.
Grey is a pretty good choice, and will certainly fit. But if orange works, it would look fantastic I think. Maybe you should order an orange sample and just try it out? If it doesn't fit you can then still go for grey.
Either way, the BF alchemy cables look pretty nice imho.
  #13
Old 25-03-13, 08:49 AM
JayCobs's Avatar
Member
I'll go with the silver/light grey flavor. I don't think the orange would look as good. Silver/light grey fits the components better. Thanks for the input.
__________________
  #14
Old 25-03-13, 09:33 AM
OC3D Elite
Happy to help Grey does go nicely with the M/B and the chrome/nickel backplates, that's true.
  #15
Old 26-03-13, 01:30 AM
badtaylorx's Avatar
badtaylorx badtaylorx is offline
Advanced Member
if you stick a 480 in the top you'll have a grand total of 1440mm...
thats a whooooooooooole lota rad.... too bad you cant mount it up on its side like bottom ones.....that would look great
__________________
http://3dmark.com/3dm11/2716743 highest 2500k+560Ti SLI TO DATE!!!
  #16
Old 26-03-13, 01:36 AM
JayCobs's Avatar
Member
Thanks for the input. I never added it all up. You are scaring me! I've decided to use a 360 for Phase 2. I don't wanna chop up the top. Geezus, I've sawed the D a great deal already. I could mount it sideways on top of the case. However, that would just DESTROY the aesthetics. Honestly I don't NEED another radiator. But, you only live once!
__________________
  #17
Old 26-03-13, 11:28 AM
OC3D Elite
Oh no! You absolutely, positively, certainly, definitely, decidedly most assuredly need that last 120 mm fan!
  #18
Old 26-03-13, 06:36 PM
JayCobs's Avatar
Member
HA! I don't think SkyNET will miss it. I guess it will depend on my mood when Phase 2 is under way.
03.27.13
UPDATE!!!
Inspiration and time to think gave me a new pump config to try out. I had to run some fluid with it to make sure it would work. Judging by the vortex I believe it's good to go!
Here are some pics of the ruff install. I don't have it completely level they way I want. I'm going to file out the bottom mount holes to give me wiggle room to level it upon final install. You probably can't tell in the pics. I'm just fussy that way.
Stay tuned...
__________________
  #19
Old 28-03-13, 06:21 PM
OC3D Elite
I just noticed: When I finally do my build with my SMH10, our internal component arrangement (radiators, PSU, res, pumps, possibly top radiator) will be quite similar
Not identical (who would want that? ), but similar.
And before I bought the SMH10 (well, before it came out) I was planning to do a scratchbuild, and ended up at the same place.
I suppose there really aren't that many possibilities to arrange your components in a square box and get best space effiency combined with clean layout.
  #20
Old 29-03-13, 11:28 PM
JayCobs's Avatar
Member
This is true. The dimensions of both cases are similar. I'll leave mounting 3 480mm rads to you. I can't WAIT to see that. Luckily, there's more than one way to skin a cat! I'm currently getting my fittings list together. I gotta get SkyNET online again. Now, where do I get the money...
__________________
Tags
480 radiator, 800d, bitspower, ekwb, heatkiller
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
