Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 20-03-13, 07:20 AM
soulreaper soulreaper is offline
Newbie
Smile Could i please have some advice on flashing a HD5970
I've had a HD5970 for a while and always had a problem in Windows 7 with
'Display driver amdkmdap stopped responding and has successfully recovered.'
Recently found a fix for this with the HD5970 Overvolt tool, have tested it well, and it does not crash if I overvolt it before I game. The volts it overclocks to are;
Engine Clock Original 1.05V to 1.1625V
Memory Voltage Original 1.10V to 1.15V
I'd like to permanently fix my card so I don't have to overvolt it every time I start a game so i've been looking into flashing it's bios with the original rom image and those voltage adjustments made permanent.
Can I do this with radeon bios editor? Is it advised? Are those safe voltages?... I can only see one 3d voltage in there under clock settings 1.05V (I'm guessing this is the Engine voltage), How would I make the change to the memory voltage as well?
The only 1.1V setting I have found is under the VTT Registers, Is this the memory voltage I am looking for?
Also under GPU Registers, there is another 1.05V under 0x18, Would I change this also?
I have a custom fan profile set with MSI Afterburner... Should I write the new bios with that too?
My card doesn't crash 2d so I don't think i'd need to change anything else...
Thanks in advance
  #2
Old 21-03-13, 02:07 AM
Newbie
Smile
Decided to go ahead and flash the bios, after 5 or so attempts (powerplay wasn't working and stuck at 3d clocks) I have successfully dialed in those voltages in the overvolt tool to the HD5970 and have powerplay working properly.
My next mission is to get the fan profile settings running correctly. I can set a fan profile in the BIOS editor, and it works up until it hits windows where driver takes over and locks it at 29/30% (right up until 100degrees~ wtf)
So.. Will make a simple thread asking about how to disable driver fan profiles.. I can't seem to find any info on the net. This is so I don't have to use MSI afterburner anymore etc...
Once i'm all done. I'll write a guide and post it for anyone experiencing the same crashes as me
  #3
Old 21-03-13, 06:47 AM
FTLN FTLN is offline
OC3D Elite
Well done mate, hope you have read up on blind flashing just in case anything goes wrong...
Tags
ati, bios, crash, flash, radeon
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
