Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 16-02-13, 01:01 PM
ExtremeTech ExtremeTech is offline
Newbie
Question VTX3D AMD Radeon HD 6670 2GB GDDR3 HELP
Heyyy Guys ,
I'm new here and just wanted to find out if it was possible for a VTX3D AMD Radeon HD 6670 2GB GDDR3 PCI-E Graphics Card to have a plastic airflow cover like http://www.aria.co.uk/dynres/cHJvZHV...I1MC5qcGc=.jpg But here is what my VTX3D AMD Radeon HD 6670 2Gb looks like
http://s1295.beta.photobucket.com/us...tml?sort=3&o=1 , where can i get the Air Flow shield or plastic fan cover , heat sink cover from ? ? Basically i would like to have the air flow plastic cover but my Graphics card never same with one ?
Regards, Drew
  #2
Old 16-02-13, 01:50 PM
tinytomlogan's Avatar
The Guvnor
You just have to buy the right model to start with.
You cant buy them seperately
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 16-02-13, 02:17 PM
Newbie
Thanks you , it would be good if you could buy them seperetly, if i brought a non working graphics card with the part , how do they attach to the graphics card on the AMD Radeon HD 6670 ?
Tags
amd, graphics card, radeon
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
