Go Back   OC3D Forums > [OC3D] Graphics & Displays > Screens and Displays
Thread Tools Display Modes
  #1
Old 30-01-13, 12:03 AM
SillyOldSquid's Avatar
SillyOldSquid SillyOldSquid is offline
Member
Send a message via Skype™ to SillyOldSquid
What monitor should i buy?
Hi all,
I am planning on buying a 27 inch monitor soon and I'm not sure what to buy.
Does anyone have any suggestions? My budget it anything bellow £300, Also I will be using it mostly for gaming and just general everyday use.
I have seen this monitor that i like so far but what do you think about it and is it worth the money id be paying for it? :
Asus MX279H 27 inch Widescreen AH-IPS Multimedia Monitor (1920x1080, 5ms, 2x HDMI, VGA, 178 Degree Wide-view Angle, Asus SonicMaster Technology).
  #2
Old 30-01-13, 12:36 AM
chrismjurd's Avatar
chrismjurd chrismjurd is offline
Advanced Member
looks a sweet monitor dude, very swish..
pricewise looks in line with the other decent branded ones £260-300 bangers
but havnt seen much of these ah-ips screens, so wouldnt like to comment on its performance, quick googles search shows some reviews commenting about light leakage, take with pinch of salt though, it looks a beltar!
and super thin bezel too, good for some trip-screens
  #3
Old 30-01-13, 12:43 AM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
If you're going for a 27" monitor, grab a 2560 x 1440 resolution monitor. 1080p at that size will not look good. Unfortunately, there are not many IPS monitors at that res under £300. Have you considered a 24" monitor at 1080/1200p, like the U2412?
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #4
Old 30-01-13, 01:00 AM
Member
Honestly anything will be an upgrade from what I'm stuck with at the moment I'm using a 32" at 1080p and it is giving me terrible headaches and eye strain so the 27" at 1080p will be better then what i have now but i do agree with you about getting a slightly smaller screen so if you could link me to what you think are the best 24" monitors for under £300 id appreciate it.
  #5
Old 30-01-13, 01:09 AM
OC3D Elite
If I was in your situation I would get one of these:
http://www.aria.co.uk/Products/Monit...roductId=45875
__________________
  #6
Old 30-01-13, 01:21 AM
Member
Awesome, got a nice little discount also.
Thanks for the advice.
  #7
Old 30-01-13, 01:22 AM
OC3D Elite
No problem dude, I hope you enjoy it
__________________
Tags
advice needed, displays, monitor
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
