Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
View Poll Results: What GPU
ASUS ATI Radeon HD 5850 0 0%
Radeon HD 6850 1GB 4 100.00%
another GTX 550 or 460 0 0%
Voters: 4. You may not vote on this poll
Thread Tools Display Modes
  #1
Old 11-01-13, 10:23 PM
Jahnkeanater Jahnkeanater is offline
Newbie
GTX 550 ti
I have had my 550 for just under 2 years and it died i cannot RMA it cause its out of warranty. My computer only has a Athlon X2 6400+ with 4 gb of ram so until I get enough money to build a new computer im stuck with what I have. I was thinking about getting either a ATI Radeon HD 6850 or a ATI Radeon HD 5850. Im not sure what is best for my computer and I dont want to spend more than $150.
attempting to reflow my 550 in the oven. :/
  #2
Old 11-01-13, 10:35 PM
CEUOTC's Avatar
CEUOTC CEUOTC is offline
Member
HD 6850 imo, sure the HD 5850 is faster (slightly) however 6850 is newer tech, and should use less power. l have just picked up a cheap GTX 560ti to rebuild my media center with a i3 3220 as l was not happy with my 5800k + 6670 build.
If you shop about you should find a bargain.
However try a reflow first as it will only cost the lecky for running the oven
__________________
  #3
Old 11-01-13, 10:47 PM
Newbie
she got a little toasty so im gonna spend a few bucks on capacitors now
__________________
PC Specs
AMD Athlon X2 6400+ x64
ASUS M2R32-MVP
x2 VisionTek Radeon HD 6850
Cooler Master 500W
Crucial 2x2gb ram
Arctic cooling freezer pro
  #4
Old 11-01-13, 10:48 PM
dragoonk dragoonk is offline
OC3D Crew
The 5850 uses a bit more power and is also faster, and the 6850 uses a lil bit less power and it's a lil bit slower. Now if you care about power and heat and that you could sacrifice a bit of performance to save some power, you'd go with the 6850. if not.. you would go with the 5870.
__________________
MB: MSI 760GM-E51 (FX)
CPU: AMD Athlon II x3 450 Rana @ 3,93GHz, 1,56 V
HDD: 1xExcelstor 160 Gb
GFX: Sapphire HD3870x2 857/1053
RAM: 2x2Gb Kingston HyperX Blu 1600 MHZ 1,65 V
PSU: Inter-Tech SL-700 700W
  #5
Old 11-01-13, 10:53 PM
Newbie
will my cooler master 500W handle a 5870? I don't really care about power consumption but with my processor also using 125W I don't want to have to buy a better power supply.
__________________
PC Specs
ASUS M2R32-MVP
Cooler Master 500W
Crucial 2x2gb ram
  #6
Old 11-01-13, 10:58 PM
OC3D Crew
Well the 5870 uses about 190 Watts so it might work but it also might not. So if you get a bigger power supply the strain on it will be smaller and the ripple will be below its limits and therefore you components will live longer. But you have the power to decide.
__________________
Tags
550, 550ti, ati, gpu, gtx
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
