Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
Thread Tools Display Modes
  #1
Old 06-01-13, 10:26 AM
DrabbleB DrabbleB is offline
Newbie
Headphones on a budget.
I have budget of between £50-£100 (that's $81-$162 US /// $80-$160 CAD) to buy some new headphones. I have ASUS Xonar Essence STX sound card, so no problems there.
I've done some research myself, Sony MDR-V6 seem to look like a pretty solid option, I've also had a chance to use these as my sister owns some already. I've also looked at Sennheiser HD 515/518, but these seem to have a narrower freq range, however I don't know how important that really is. ( I know the human hearing range is only meant to go up to about 20kHz anyway.)
I'm not an expert on headphones AT ALL, hence I'm here asking for advice. Any help will be very much appreciated.
Thank you all for your time.
  #2
Old 06-01-13, 10:57 AM
PEXON's Avatar
PEXON PEXON is offline
SleevingMaster
Send a message via Skype™ to PEXON
HD518 or the DT770 if you can stretch to it.
__________________
El Jefe of Sleeving
  #3
Old 06-01-13, 11:17 AM
Newbie
Thanks.
  #4
Old 06-01-13, 12:13 PM
Tomtom565's Avatar
Tomtom565 Tomtom565 is offline
Member
Send a message via Skype™ to Tomtom565
I personally would go for the DT770's, but that's because like Pexon, I own a pair , and would thoroughly recommend them, great value and built like tanks. However I do know someone with the AKG K271 MKII's, and he loves them and when I used them I found they where quite comparable to the beyers but the high's where rather muffled
__________________
Desktop
Laptop
  #5
Old 06-01-13, 12:55 PM
jamesriley94 jamesriley94 is offline
OC3D Elite
Pexon doesn't own a pair... His broke
He did recommend for me to get them though - and I can say he did make a great choice!
  #6
Old 06-01-13, 12:59 PM
PEXON's Avatar
SleevingMaster
2000 hours of burning in time on them, then the driver popped and I tried fixing it and I think I destroyed them even more. I miss them so bad.
__________________
El Jefe of Sleeving
  #7
Old 06-01-13, 01:37 PM
Tomtom565's Avatar
Member
You got some too James? I take it that Beyer took them in under warranty Pexon? I feel for you man...
__________________
Desktop
Laptop
  #8
Old 06-01-13, 01:47 PM
PEXON's Avatar
SleevingMaster
Considering I ripped them apart and had a go at resoldering them, they won't take them back. I spent a whole day tinkering with them trying to get them back to life, but the right driver still wouldn't work. The left one worked no issues though
__________________
El Jefe of Sleeving
  #9
Old 06-01-13, 02:06 PM
Deejeta Deejeta is offline
Advanced Member
With that decent sound card invest in some studio monitor headphones even low end ones. Treat your ears.
AKG's, Berringer.
__________________
"Western civilization is a loaded gun pointed at the head of this planet." McKenna
  #10
Old 06-01-13, 02:08 PM
Tomtom565's Avatar
Member
Originally Posted by Deejeta View Post
Berringer.
Nooooooooo
__________________
Desktop
Laptop
Tags
headphone, headphones
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
