Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 22-12-12, 03:38 PM
benito benito is offline
Newbie
New Cooling Loop questions
hey guys,
i am looking to get into water cooling. right now i am running a 3770k at 4.5 GHz at 1.224v. my room temp right now is around 18c and my idle temps are 33c package. at load with prime95 for 1 hour we get to 85c. but bear in mind that it is pretty cold ambient, so in the summer i have seen max temp reach 94c...pretty bad. right now i am cooling with the noctua beast NHd14.
so for summer i want to put in a custom loop now, during holiday. so i am going to get the "XSPC Raystorm RX360 Universal CPU Water Cooling Kit w/ D5 Variant Pump Included" and as the specs mention this does not come with fans.
so what kind of fans should i get? i want something quiet so i was thinking of the corsair sp120 quiet editions. but then i saw that there are "high static pressure" and "high airflow" editions.
so what would be best for the RX360, and how much would temps differ in a push/pull, versus a push or pull config?
my next question is coolant. i want a solid color so really the obvious choice is mayhems pastel. oh i already answered my question because that stuff is great. so i thought. i live in the US, and mayhems re-sellers only carry the concentrate. HOFSMH. so i need to mix the the stuff, but i don't understand how to do it. i know that if i was going to use the regular dye i would mix with DI water i would need the x1 treatment, right? but if i want to use the pastel. do i mix it with DI water and x1 treatment or do i just mix it with DI water? and how much x1 treatment do i use? i want the green, but i am also going to want to add more green.
i should also add that i want a custom loop over a closed loop solution because eventually i will want to add the GPU to the loop. i am pretty sure i will need another rad but i am not sure.
any help will be appreciated.
  #2
Old 22-12-12, 03:44 PM
B NEGATIVE's Avatar
B NEGATIVE B NEGATIVE is offline
OC3D Elite
The RX is a low speed fan optimized rad,it will work with most fans.
I use the corsairs myself.
Dont bother with push/pull,that works better with high FPI rads such as the GTX.
__________________
  #3
Old 27-12-12, 03:53 AM
WenHan WenHan is offline
Newbie
Just add the required amount of distilled water to the concentrate.
Example: For Pastel, add 750ml water per bottle of concentrate. For X1 add 1750mL of water per bottle of concentrate.
  #4
Old 04-01-13, 05:43 AM
Newbie
hey guys/girls, i really need some input on some rads. i have max clearance of 90mm, so my question is what would be best:
XSPC RX360 in push only config (83.5mm)
or
XSPC AX360 in push/pull config (90mm, Pushing clearance limit)
or
any Rad in push or push pull that will fit in the 90mm space <$100 USD
  #5
Old 04-01-13, 05:57 AM
airdeano airdeano is offline
OC3D Elite
the XSPC RX, Alphacool UT, Hardware Labs SR1 are 55-60mm thickness. and there
are others. like B suggested, the lower FPI rads do not need the push/pull config.
and stepping into a thinner radiator to run push/pull is slightly walking backwards.
most of the Raystorm 360/D5 kits ($299) ive seen all include the XSPC 1650 fans.
and what case is this all going into?
  #6
Old 04-01-13, 06:15 AM
Newbie
i was about to edit when i saw that you had replied.
i want to use corsair SP 120's preferably QE's.
this is all going in a modded CM Storm Trooper.
i will also get a 240 rad in the bottom identical to what is chosen for the top. and i will also be ditching the kit and go for a completely custom loop.
  #7
Old 08-03-13, 03:58 AM
Newbie
link in my sig to what i ended up with
__________________
My Rig NoName, CM Storm Trooper
Tags
fans, mayhem, raystorm, rx360, xspc
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
