Thread Tools Display Modes
  #291
Old 18-03-14, 09:01 PM
MathiasBE's Avatar
MathiasBE MathiasBE is offline
Newbie
Originally Posted by nikkop View Post
Thanks mate. Glad it's appreciated To be honest I have already started sketching on a new tiny project that I would like to come true. But I do not see myself using it afterwards since my current PC will outperform a lot. I might perhaps do the project, I'll have to think about it! :P
I'll try to stay active here as much as possible and who knows, I might come back with something new soon! (even tho I must resist the urgue to do so, haha).
/nikkop
Talking about m-itx?
Because those build really are right up my alley!
__________________
I'm not a native speaker don't shoot me for making mistakes ~ Mathias
  #292
Old 18-03-14, 09:26 PM
chewythefirst chewythefirst is offline
Member
it turned out excellent man, big props for the hard work you put into it.
__________________
Corsair 800D/ 16gb Corsair Vendgea LP 1866mhz / Radeon R9 290x / XSPC 290x CPU block / EK res and pump / EK 360mm x 60mm rad / XSPC compression fittings / AMD FX 8-core Black Edition FX-8320 / Heat Killer 3.0 LC customized CPU block /Gigabyte Socket am3+ GA-990FXA-UD3/Samsung 830 series 64gb ssd/ WD 2tb 7200rpm.
Tags
big bro, bitfenix, gigabyte, prodigy
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
