Go Back   OC3D Forums > [OC3D] Hardware & Software > Storage Mediums
Thread Tools Display Modes
  #1
Old 15-12-12, 03:48 PM
Mix Mix is offline
Newbie
Post For Gaming Only
OK fist off please read the list below as it will inform you of the parts I will be using. Secondly money is not an object, I want the very best not the second best. Third please don't comment on the rig I will post another thread for that.
Asus PB278Q Monitor
Blue Ray Drive
7930K processor
Rampage IV Extreme Mobo
Coolermaster Cosmos 2 Case
Windows 7 64-bit Home OS
Evga SuperNova Nex 1500 PSU
8 G-Skill 8 GB RipjawsZ RAM
2 Nvdia GTX 690 GPU
Crucial M4 512GB SSD
Now my question is which is better for gaming only the WD Velociraptor 1TB or the Momentus XT 750GB as I can't find any real world comparisons only benchmark tests
Thanks Mix
  #2
Old 15-12-12, 03:50 PM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
Youll want the most capacity for games as theyre getting bigger and bigger. The Raptor 1TB would be my choice out of those 2.
Now hurry up and get that thread up concerning your rig cause Ive really gotta talk to ya about that power supply!
__________________
AMD R5 1600X @ 4.0 GHz ••• Asus ROG Strix X370-F ••• Corsair H110i
Corsair 500R ••• EVGA Supernova G3 750 ••• Corsair Vengeance 16GB
Western Digital Caviar Black 1TB x2 ••• Nvidia RTX 2070 FE
Samsung 840 Evo 250GB ••• Acer Predator XB272 @ 240 Hz
Logitech G-Pro TKL ••• Logitech G MX518
  #3
Old 15-12-12, 03:52 PM
jamesriley94 jamesriley94 is offline
OC3D Elite
lol...
Seriously dude, there's no way people aren't going to comment on this rig.
2 690s will actually reduce performance. And if it's for gaming you're better off with 1155 and a 3570k or 3770k instead of the 3930k.
If money's no object, why not get another SSD and put everything on there? Not sure how you'd fill more than 512gb on an SSD with games?
You have way more problems with this rig than which hard drive to buy...
  #4
Old 15-12-12, 03:53 PM
Yeren Yeren is offline
Advanced Member
for gaming stick your games on the SSD that you have bought
the veliciraptor should be replaced with a WD caviar black
2 690's is just stupid, just get 2 x 680's
7930k processor?
1500w PSU is just ludicrous
__________________
3770k -- Asus P8Z77 V-PRO --
Corsair H100i --
16GB Corsair Dominator Platinum 2133MHz
EVGA GTX680 Superclock Signature 2
AX760i -- 256GB Crucial M4
CoolerMaster Stryker
27" 2560x1440 Monitor
  #5
Old 15-12-12, 03:59 PM
MacLeod's Avatar
OC3D Elite
OK fine, since Im not the first one Ill not bite my lip.
That power supply is awful in addition to being WAY overpriced. Its getting shredded by review sites as just being horrible and failing tests and all that. For a lot less money, get a Seasonic Platinum 1000 or 860 watt. Those are the best power supplies on the market right now.
A pair of GTX690's would be overkill even for 5760x1200 resolution. Thats 4 GTX680's which is just crazy.
And there is no such thing as a 7930K. Obviously youre talking about a 3930K which is an outstanding processor so good choice there.
Trim off a GTX690 and get that Seasonic Platinum and youll be set.
__________________
  #6
Old 20-12-12, 08:48 PM
Christoi Christoi is offline
Newbie
There's really no point going for Velociraptors these days, as the 7200.14 Seagates are only slightly worse in terms of performance and any modern SSD's thrashes them. The Momentus XT is just a hybrid drive, so there's no point using it as a storage drive either.
  #7
Old 20-12-12, 09:21 PM
WilliW WilliW is offline
Newbie
2 x Samsung 840 Pro 512GB in Raid-0 and
WD Green 2TB to take daily incremental backups with Acronis TrueImage (or similar).
  #8
Old 20-12-12, 10:06 PM
B3rni3 B3rni3 is offline
OC3D Crew
Dude if money is no object like you say just get a second 512gb ssd it will be faster and quieter than any hdd, then get a green hard drive for media storage.
512gb should be loads for games anyway. Think of it this way max payne 3 which is a huge game according to steam needs 35gb of space. Now that game is huge as in 2-3 times bigger than bf3. You would be able to install MP3 on a single 512gb ssd nearly 13 times if you exclude windows being on there too.
As for the rest of your rig I cant really comment on it as it just hurts my head way to much because your post contradicts itself a few times.
__________________
Case: Cosmos 2 Cpu: 3930k @ 4.6 ghz Mobo: Sabertooth CoolerH100 with Sp120 Quiet ed Ram: 16GB Vengence Gpu: Gtx 680 Sli w/ EVGA Backplates Psu: Ax760 Hdd: 2TB seagate green Ssd: 120GB Corsair Force GT + 240GB Sandisk Extreme
Nr. #002
  #9
Old 20-12-12, 10:11 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
And it's even the same Mix as the other thread you just posted on! With an almost identical overpowered gaming set-up...
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #10
Old 20-12-12, 10:15 PM
OC3D Crew
Ya I know I found his other rig after I saw this but I posted in the other thread as I was there before I came back here.
That makes my rig look weak and my rig is a bit overkill for gaming as they wont use the 3930k. But then I didn't buy my rig just for gaming.
__________________
Nr. #002
Tags
gaming hdd, hard drive, hdd, momentus xt, velociraptor
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
