Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 25-06-12, 01:51 AM
Trax0r-DnB Trax0r-DnB is offline
Newbie
POV TGT GTX570 Bios
Hey there!
I was looking for a bios update for my POV TGT GTX570 Beast Charged Edition (http://www.drivecity.de/product_info.php/info/p746740) but couldn't find anything. Could someone point me in the right direction..if such an update does happen to exist?
Cheers
  #2
Old 25-06-12, 08:29 AM
Newbie
Btw, my current bios version is 70.10.38.00.70
  #3
Old 26-06-12, 10:33 AM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
People usually don't update the bios if they are having no issues with the current version. Are you having issues with the card?
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #4
Old 03-07-12, 07:35 AM
Newbie
Thanks for replying yassarikhan.
I'll try to explain a bit more in-depth with this post now:
So my card comes factory overclocked: core: 772 (linked with shader clock); mem: 1900; corevolt: 1025mV.
If I raise only the core to 840 and either leave the core voltage as it is or increase it to 1040mV I start seeing artifacts in games like Battlefield 3 and Crysis 2. I have read cases where people have not seen artifacts with the above-mentioned overclock settings. It can't have to do with overheating because my card never ever gets hotter than 70°C.
However if I raise the core voltage to 1060mV there are no artificats to be seen. After I have described my current situation, do you think that raising the core voltage to 1060mV is not too risky and that the artifcats which I saw were caused by an insufficient power supply to the graphics card?
Cheers
ps: I have heard that some areas of the gtx570 series cards can get hotter than others and that capacitors have been heard to blow/fry.
  #5
Old 03-07-12, 09:04 AM
OC3D Elite
You have to remember that all cards are different. Some will overclock better than others. You can't expect to have the same settings as other people. After you raise the voltage to 1060mV, how hot does the card get? If it doesn't go over 80 C and you see no artifacts than I would leave it at that. I don't think a BIOS update would allow you to use a lower voltage to achieve the same overclock.
__________________
  #6
Old 03-07-12, 09:17 AM
SieB's Avatar
SieB SieB is offline
OC3D Elite
Some custom BIOSs give better overclocking than others.
Not sure what BIOS are available to flash your card with though, Google is your friend for finding one though, Trax0r-DnB. Unless anyone here can point you in the direction.
__________________
NZXT Switch 810 - i7 6700K - MSI Z170A Krait - 32GB Corsair Platinum SE - MSI 1070 - Crucial MX100 256GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair RM1000i SE - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
Tags
570, beat, bios, gtx
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
