Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #11
Old 10-08-17, 04:55 PM
Gothmoth Gothmoth is offline
Member
intel always had a compiler advantage.
i am sure this fact also plays a role in a lot of real world benchmarks, not only better raw IPC power.
and the last years of AMD stumbling around with bulldozer etc. sure did not help making things better.
i only hope that software companys catch up and do proper optimizing.
4 cores and 8 threads can not be treated as "upper maximum" anymore.
especially companys like adobe have a lot of work to do when it comes to multicore support.
H.265 performance is basically a good as intels 7900x (41.3 vs 42 fps/s).
H.264 is better (53.9. vs 50.3) nothing to complain about for the same amount of money.
numbers are from anandtech.
  #12
Old 10-08-17, 04:59 PM
RickPlaysWarr's Avatar
RickPlaysWarr RickPlaysWarr is offline
Advanced Member
Epic review Tom! This is the top of the line setup that I would want. I can't wait to see what happens when you throw the EK waterblock just announced today on this beastly boy. Better yet, an EK monoblock would be awesome and get rid of that annoying tiny VRM heat-sink fan. Did you use all 4 memory channels or just two in the review testing?
Thank you so much for putting the thought and time into this review.
__________________
  #13
Old 10-08-17, 05:41 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Originally Posted by RickPlaysWarr View Post
That was the total system draw from the wall during OC testing. The CPU was drawing a huge part of that. So a Threadripper CPU rated at 185 TDP can gobble up a lot more power if it needs it for Overclocking.
I can't remember who said it (I've read so many reviews my head is spinning) but they basically said you could run a 16 core TR rig as about four separate PCs. So file server, gaming, web hosting ETC. When you think about it like that (and let's face it that would be a far more practical use than banging out Cinebench scores) the power consumption doesn't seem so bad.
__________________
He used to do surgery
For girls in the eighties
But gravity always wins
If you ever ask me something and feel insulted by what I said back ask yourself this.. Would you rather I pretend and give you the answer that is expected, or, tell you how it really is?
  #14
Old 10-08-17, 06:06 PM
Member
depends... cinebench is the most relevant benchmark for me.
because it translates 1:1 into rendering performance with cinema 4D.
and that is what pays for the computers i build.
  #15
Old 10-08-17, 06:08 PM
SDG Stryker SDG Stryker is offline
Newbie
5930K Bruh
I'm gonna need yall to include the 5930K in these D:
We need some valid representation of some of the older flagship CPUs
  #16
Old 10-08-17, 06:37 PM
AlienALX's Avatar
OC3D Elite
Download Cinebench R15 and run it. You will score a max of around 1300. Then compare that to Ryzen and Threadripper. It's about the most accurate "full CPU" test there is.
__________________
  #17
Old 10-08-17, 09:21 PM
Korreborg's Avatar
Korreborg Korreborg is online now
OC3D Crew
Plex = 2000 passmark points for a 1080p/10Mbps transcode.
Thats a lot of transcodes from this CPU
But still not that much better than a 10 core CPU??? (I know price, but still)
__________________
[I7-4790K @ 4.5Ghz][ASUS Z87I-PRO][EVGA 1080TI FE][Kingston HyperX 16GB 2400MHz][Corsair 250D][Corsair AX860i]
[Samsung 850 PRO 128][Crucial MX100 512GB][WD 2TB][ASUS PG278QR][Logitech G510s and G502][Steelseries Wireless H]
  #18
Old 11-08-17, 07:00 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Thanks for the review Guv and boy oh boy is that one beastly CPU and I really like that Asus board too
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=Asus X370 ROG Crosshair VI Hero=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Trident RGB= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #19
Old 11-08-17, 07:36 AM
Eddie long's Avatar
Eddie long Eddie long is offline
Member
what a beast ,and it will get better over time with bios updates , much as i adore the board , i would never use the chip to its potential , but its nice to dream
  #20
Old 11-08-17, 08:26 AM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
I was eagerly awaiting reviews of Threadripper to pop up yesterday. Didn't do too much at work after lunch as a result....
Anyway, I'm sure it's likely the 16 core i7-7960X will top the Threadripper 1950X when it releases but I'm wondering does it matter?
The Threadripper 1950X in comparison has:
ECC Memory Support
Far More PCIe lanes
& is 70% cheaper.
It kind of makes you wonder why you'd bother looking at an Intel X299 setup at all if a workstation is what you want.
So nice to have actual excitement in the CPU market again - Thanks AMD!
And thanks to Tom for the review as always.
__________________
Main: Intel i7-6700k | MSi Z170i Gaming Pro AC | 16GB Crucial BallistiX DDR4-2400 | Nvidia GTX 1070 | Fractal Define Nano S
Secondary: AMD Phenom II X4 955 | Gigabyte GA-MA790FXT-UD5P | 8GB Corsair DDR3-1333MHz | Nvidia GTX 750Ti
Server: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair ValueSelect DDR3-1333MHz | MiniBox M350
HTPC: AMD A6-6400k | Gigabyte GA-F2A88XN-WIFI | 8GB Kingston DDR3-1600MHz | Silverstone ML03
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
